Forum Topic - how to bring shell builtin into QNX 6.6 QT 5.3.1:
Hi QNX,
       qnx sdp 6.6,
       BSP_ti-am335x-beaglebone_br-660_be-660_SVN797070_JBN574.zip
       beaglebone black Rev. C
       QT 5.3.1
I implemented a QT program similar to https://evileg.com/en/post/261/
input filesystem command such as "ls", which will list the files under current directory. and "pwd" will show the
current directory path. "ls" / "pwd" and lots of other commands are available @ /opt/qnx660/target/qnx6/armle-v7/bin,
however there is no "cd" since 'cd' is a shell builtin.
Please advise how I can bring the shell environment into this QT program, in which then I am able to use "cd" to
change directories.
Thanks in advance
Mike
Re: how to bring shell builtin into QNX 6.6 QT 5.3.1
You can run "ls" and so on - can you run "ksh"?
Hi Malte Mundt,
As suggested, I tried "ksh", then no commands can be executed ever since. i.e., "ls" or "pwd" will bring the content of
the current directory; then input "ksh", no response as expected; after that,  "ls" or "pwd" also stops working.
I checked that the "ksh" is available @
# find -iname "ksh"
./proc/boot/ksh
./base/bin/ksh
Please advise, thanks in advance
Mike
