Forum Topic - QQnxScreen:failed to query screen mode. Using default value of 60Hz:
Hi, all:
Due to the demand of the 3D,I compiling Qt5.6.2 under QNX6.6;
when i use Qt3D.Core or Qt3D.Render, run application in VM return error log:
and SceneLoader Component used in my application Status=Error;
What reason is this?
QNX6.6 does not support  Such as the Qt3D.Core module development?
Who can give me some help.
Thanks.
Re: QQnxScreen:failed to query screen mode. Using default value of 60Hz
The message isn't reporting a problem that would affect Qt3D functionality.
What are you running this on?
Hi:
I am running a QML demo with Qt5.6.2, and have 3D.Core component in demo, I know the basic problem is that 3D run failed
, but i do not know the reason.
can i use QT5.6.2 under QNX6.6 correctly? if not, what are the limits(3D part is the key point)?
I've run Qt3D applications (the planets example) on 6.6.0 but it's been a while since I did this.
I've used Qt 5.6.2 on 6.6.0 but I haven't used Qt3D 5.6.2 on 6.6.0.
Are you trying this in the virtual machine or an actual device?  What kind of device?
My QNX6.6 currently run in Win 7 VM, but this is for debugging, my real work device is embedded ARMV7, and  run Qt3D
failed,
Maybe I should stick with QT5.3, but change the thinking development of 3D.
I am trying to now, do you have any good Suggestions can give me
The Qt planets example works with Qt Enterprise 5.6.2 on an OMAP5 board (TI-5432) with the Apps and Media 1.1 image.
Any other example that I try produces "QOpenGLShader::link: "Link Error: Vertex shader is missing.\nLink Error: Fragment
 shader is missing.\n""  I'm guessing Qt does something that the QNX OpenGL implementation doesn't like :-(.
Hi:
You're right, so now I return to QT5.3, use native opengles2 development 3D, but I don't know how to combinate it and
QML window together
