Forum Topic - UDP messages on a Beagle Bone Black:
I have written an application that monitors UDP messages on port 53248 for any ethernet adapter present in a system.  It
 works great with the x86 based QNX VM.  I am now trying to deply it on a Beagle Bone Black.  I reran qmake using the
arm version and built the program again.  All the right compilers are used to build for the arm architecture.
When I run the prgram, the readyRead SIGNAL is never fired.  Has anyone attempted to use readyRead SIGNAL on ARM
architecture?  I am baffled as to why the program does not just compile and work?  Any suggestions would be greatly
appreciated at this point.
Thanks.
Re: UDP messages on a Beagle Bone Black
I solved the issue.  For some reason, I needed to use io-pkt-v6-hc as the driver for the ethernet adapter instead of io-
pkt-v4-hc.  Once I updated the BeagleBone BSP to use the other version, everything worked fine.
Interesting, thanks for sharing your solution!
