QNX 6.6 touch screen setup
09/01/2014 11:29 PM
post111604
Hello.
I'm trying to use touch screen at QNX 6.6 / Qt5.
I've searched and followed answers and then I'm seeing calib-touch screen now.
But I can't move the cursor or click.
After launching below programs in rc.local, calib-touch program could be run.
But touch doesn't work and cannot calibrate.
With QNX 6.5 / Qt4 touch screen works fine.
Does anyone have any idea what's wrong?
Thanks.
io-usb -duhci -dohci -dehci
io-hid -dusb -degalax
devi-hid kbd touch
drm-intel &
screen &
Here is hidview result:
# hidview
Device Address : 0
Vendor : 0x0eef (eGalax Inc.)
Product : 0x0001
Version : r1.10
Usage : Pointer
Device Address : 1
Vendor : 0x045e (Microsoft)
Product : 0x0752 (Wired Keyboard 400)
Version : r1.10
Usage : Keyboard
And this is my env variables:
# env
_=/usr/bin/env
SSH_CONNECTION=192.168.100.118 64713 192.168.100.177 22
PATH=/sbin:/usr/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/opt/bin:/opt/sbin:/bin:/sbin:/usr/bin:/usr/sbin
SHELL=/bin/sh
TMPDIR=/tmp
HOSTNAME=localhost
USER=root
PROCESSOR=x86
MAIL=/var/spool/mail/root
LD_LIBRARY_PATH=/prob/boot:/lib:/usr/lib:/lib/dll:/opt/qt5/lib:/opt/qnx6/x86/lib:/opt/qnx6/x86/usr/lib:/opt/qnx6/x86/lib
/dll:/usr/lib/graphics/intel-drm:/opt/qt5/plugins/platforms
QT_DEBUG_PLUGINS=1
HOME=/root
SSH_CLIENT=192.168.100.118 64713 22
QNX_HOST=/
QT_QPA_PLATFORM=qnx:no-fullscreen
QNX_TARGET=/
GRAPHICS_ROOT=/usr/lib/graphics/intel-drm
QQNX_PHYSICAL_SCREEN_SIZE=200,117
TERM=xterm
QML_IMPORT_PATH=/opt/qt5/imports
QML2_IMPORT_PATH=/opt/qt5/qml
QT_PLUGIN_PATH=/opt/qt5/plugins
FONTCONFIG_FILE=/etc/fontconfig/local.conf
QNX_CONFIGURATION=/etc/qnx
SSH_TTY=/dev/ttyp0
SYSNAME=nto
LOGNAME=root
This is my /usr/lib/graphics/intel-drm/graphics.conf:
begin khronos
begin egl display 1
egl-dlls = libEGL-mesa.so
glesv1-dlls = libglapi-mesa.so libGLESv1_CM-mesa.so
glesv2-dlls = libglapi-mesa.so libGLESv2-mesa.so
end egl display
begin wfd device 1
wfd-dlls = libwfdcfg-sample.so libWFDintel-drm.so
# Run "drm-probe-displays" to list the available displays and pipelines,
# and "use $GRAPHICS_ROOT/libWFDintel-drm.so" for more information on
# these driver-specific settings.
# Pipeline IDs 1 to 9 are used for DRM CRTCs. One should be assigned
# to each display that will be used.
pipeline1-display = 1
# Pipeline IDs 10 and above are used for DRM planes. A plane can only
# be used on a display with an active CRTC.
pipeline10-display = 1
end wfd device
end khronos
begin winmgr
begin globals
input = keyboard mouse
# Adjust the stack size of Screen's resmgr threads. The default size
# is insufficient for blitters/compositors using Mesa (e.g., gles2blt).
blit-config = gles2blt
end globals
begin display 1
video-mode = 1024 x 600 @ 75
# Adjust the stack size of Screen's composition thread; required when the
# display's framebuffer uses Mesa (e.g. "usage = gles2"), as noted above.
cursor = on
stack-size = 4096 # in units of 1024 bytes
end display
begin class framebuffer
# Be sure to configure the "pipeline%d-display" options (above) so the
# specified display and pipeline are bindable. Normally a framebuffer
# will use a CRTC pipeline.
display = 1
pipeline = 1
format = rgba8888
usage = gles2blt
end class
begin mtouch
driver = devi
options = height=600,width=1024
display = 1
end mtouch
end winmgr
