08/06/2014 5:32 AM
post111323
Just by a chance, I retested this my SDP 6.6 with Apps&Media on a 5.3.1 source tar-ball. I did not get your error, but
when "-fully-process" is used the build fails in webkit which is known. Do you have a good reason to use "-fully-process
"? Other then that there are no build problems. You call of configure is rather complicated. I hope, you know what all
options in your configure are doing. Normally, just "-prefix" and "-xplatform" are sufficient. Certainly, using other
options helps tuning, but using them blindly is not a good idea... ;-)
Your build problems might also be caused by some leftovers from a previous "configure" call. The well-known "make clean"
does not remove all the stuff created by "configure". You need to clean your src folder with "make distclean" to get it
really clean.
Compared to 5.2, Qt 5.3 has a new JavaScript engine. I'm sure that is the reason why "-no-javascript-jit" is not
provided anymore.
