Run Qt 5.2.0 at QNX 6.6 VMware target
05/06/2014 3:01 AM
post110156
Hello everybody! I download Qt 5.2.0 from this link: "http://community.qnx.com/sf/frs/do/viewRelease/projects.qt/frs.
binpkg.qt_5_2_0_development_environment", and build it for QNX x86 target with this configue command: "configure -
release -nomake examples -nomake tests -prefix C:\QtQNX\qt5-5.2_x86 -platform win32-g++ -xplatform qnx-x86-qcc -opengl
es2 -no-cups -no-iconv -skip qtserialport -skip qtwebkit -mp", after "make" and "make install", I copy all "C:\QtQNX\qt5
-5.2_x86\" qnx qt library files to my QNX 6.6 vmware target. At QNX 6.6 vmware target, I also run "export
QQNX_PHYSICAL_SCREEN_SIZE=150,100" comman for Qt application environment.
After finshed things above, first I build a Qt console application and download it to QNX 6.6 vmware target, the
console application could run on QNX target successful. Then, I create a Qt base GUI application with default source
code and download it to QNX target,
but, this application run failed. I am sure my screen system is ok, because I could see "screen" device node at "/dev",
and also, after run "screen" command, I could move mouse with cursor at QNX 6.6 target. Why the Qt GUI application
failed? I don't know. From the slog2info, I find the error message, the content is: "This application failed to start
because it could not find or load the Qt platform plugin "qnx".Reinstalling the application may fix this problem.".
What's the meaning it is?
