Re: ldd:FATAL: Could not load library libQtGui.so.4
12/30/2013 7:26 AM
post107736
As with any shared library, it must be present on the disk, it must match the target architecture, and the location must
be found in the LD_LIBRARY_PATH variable.
If you believe those requirements are met, try starting your Qt executable like
# DL_DEBUG=1 ./cEasy
The verbose output will show where the loader is looking for each library required by the binary.
