ldd:FATAL: Could not load library libQtNetwork.so.4
11/11/2012 7:57 PM
post97069
I'm working to run qtdemo on OMAPL138.
But I have an error like below.
#qtdemo -qws
libs: load_object: attempt load of libQtGui.so.4
debug: find_file:1151: name=libQtGui.so.4
libpath=/proc/boot:/lib:/usr/lib:/lib/dll:/opt/lib rpath=NULL
debug: searchpath:1095: name=libQtGui.so.4 path= amode=4 bufsize=1025
path=/proc/boot:/lib:/usr/lib:/lib/dll:/opt/lib amode=4 bufsize=1025
debug: searchpath:1119: trying /proc/boot/libQtGui.so.4
debug: searchpath:1130:/proc/boot/libQtGui.so.4: failed (No such file or
directory)
debug: searchpath:1119: trying /lib/libQtGui.so.4
debug: searchpath:1130:/lib/libQtGui.so.4: failed (No such file or
directory)
debug: searchpath:1119: trying /usr/lib/libQtGui.so.4
debug: searchpath:1124:/usr/lib/libQtGui.so.4: success
libs: /usr/lib/libQtGui.so.4: found; real path:/usr/lib/libQtGui.so.4
libs: load_elf32: loaded lib at addr 200000(text) e4fa68(data)
libs: object libQtGui.so.4 loaded; real soname: libQtGui.so.4 loaded from:
libs: load_object: attempt load of libQtNetwork.so.4
debug: find_file:1151: name=libQtNetwork.so.4
debug: searchpath:1095: name=libQtNetwork.so.4 path= amode=4 bufsize=1025
debug: searchpath:1119: trying /proc/boot/libQtNetwork.so.4
debug: searchpath:1130:/proc/boot/libQtNetwork.so.4: failed (No such file or
directory)
debug: searchpath:1119: trying /lib/libQtNetwork.so.4
debug: searchpath:1130:/lib/libQtNetwork.so.4: failed (No such file or
directory)
debug: searchpath:1119: trying /usr/lib/libQtNetwork.so.4
debug: searchpath:1124:/usr/lib/libQtNetwork.so.4: success
libs: /usr/lib/libQtNetwork.so.4: found; real
path:/usr/lib/libQtNetwork.so.4
#set
DL_DEBUG=1
HOME=/
IFS='
KSH_VERSION='@(#)PD KSH v5.2.14 99/07/13.2'
LD_LIBRARY_PATH=/proc/boot:/lib:/usr/lib:/lib/dll:/opt/lib
MAILCHECK=600
OPTIND=1
PATH=/proc/boot:/bin:/usr/bin:/opt/bin:/sbin:/usr/sbin
PHFONT=/dev/phfont
PHOTON=/dev/photon
PHOTON_PATH=/usr/photon
PPID=1
PS1='# '
PS2='> '
PS3='#? '
PS4='+ '
PWD=/
QWS_DISPLAY=qnx
QWS_KEYBOARD=qnx
QWS_MOUSE_PROTO=qnx
RANDOM=17504
SECONDS=52973
SHELL
SYSNAME=nto
TERM=qansi
TMOUT=0
VASC_SHIMDIR=/lib/dll
_=set
Thanks in advance for any tip.
Patrick
