Debugging Qt apps with Momentics IDE - "Take Two"
06/19/2012 4:38 PM
post93774
https://dl.dropbox.com/u/13676760/Qt_debugging_rev2.pdf
This document is accompanied by an archive containing a "roll-up" of the
examples presented elsewhere in this forum. Each is packaged to be built
specifically under Windows command-line.
Using the provided cEasy command-line source as a starting point, the document
walks through the process of converting cEasy to an IDE project. The finished
project allows building the source for debug, setting up up a target, and
running a source-line debug session.
A second archive contains a completed IDE workspace containing the the same
four projects. Using the ready-to-run i.mx53 or Beagle-xm target images cited
in the docunment, you can immediately build in the IDE and begin source-line
debugging.
Links to the archives are at the end of the pdf.
