05/17/2012 9:54 PM
post93170
hello ,i'm new to qt/qnx,now i encounter a question ,that is how i run my own qt app on the target based on qnx (my host
is winxp,and target is vmware).i don't really know how it works, i guess:
1)the first step : i make a project by qt-creator and run ,debug to make sure it will run well.
2)the second step : i make the resource that is needed to run on qnx again .
According to this thought,i did the following things:
1)first i create a project "hello world" in the qt-creator ,and it works well
2) as the "read me"says,i enter C:\Qt\hello,and create a makefile including
"LIST=OS CPU VARIANT
MAKEFILE=GNUmakefile
include recurse.mk
##eof"
3)Inside the same directory, create subdirectories called nto-x86-o,including "GNUmakefile"
ifndef QCONFIG
QCONFIG=qconfig.mk
endif
include $(QCONFIG)
include $(MKFILES_ROOT)/qmake-qt.mk
##eof
4)from cmd prompt,i enter the C:\Qt\hello,and run "make" ,but it shows mingw32-make is Not internal or external command
, also not be operation of the procedure or a batch file.
5)so i enter"ksh",run "make",it shows errors as the attachment shows ,but it produce a .project and a hello file.so i
transfer the hello file to the vmware ,the app absolutely failes to run .
another question ,i know that qt can be intergrated with eclipse which makes the developer convenient,however, can it
be intergrated into the momentics (run and debug in the momentics environment)?
thank you ,and I look forward to your reply
