Re: Qt speedometer example performance issue
01/24/2012 9:50 AM
post91102
NOTE regarding performance -
I did all my testing for this example on i.mx53QSB (armv7). The SD card filesystem I was using had Qt 4.8.0 binaries
installed. The motion is smooth and there is a minimum of a few percent idle time reported.
When I reverted back to the 4.7.1 binaries, I discovered the example behaves very poorly! With 4.7.1, the CPU
requirement exceeds 100% so the motion is very jumpy! Apparently, lots of improvements for the relatively "new"
declarative model have gone into the baseline.
I have prepared a zipfile with the 4.8.0 runtime binaries and files to support speedo (and the other Qt examples I have
posted). Just apply the archive to the root of your runtime filesystem. If the example utilizes .jpg images, you will
need to "export QT_PLUGIN_PATH=/usr/lib/qt4/plugins" prior to starting the Qt binary.
The zipfile is: http://dl.dropbox.com/u/13676760/armv7-runtime-4.8.0.zip
