Forum Topic - Notes on building Qt 4.8.0 from the Nokia repository:
The following pdf details using a Linux host to build Qt 4.8.0 for QNX from the repository, cross-comple Qt Creator
applications, and deploy them on a QNX 6.5 embedded target.
http://dl.dropbox.com/u/13676760/QtBuild.pdf
Re: Notes on building Qt 4.8.0 from the Nokia repository
An archive of the applications discussed is here:
http://dl.dropbox.com/u/13676760/apps.tar
Thanks for you tutorial.
Did you tested to build OpenGL module also?
Baris
I did not test openGL.  Please share your results here if you do!  Thanks.
In the pdf associated with this thread, I described testing the 4.8.0 libraries on the i.mx53 "VGA" image.  Not only did
 the 4.8.0 libraries work, but intensive graphics used noticeably less CPU.
However, when I deploy the libraries on i.mx53 with LCD and touchscreen, the same applications are not usable.  The
touchscreen only occasionally recognizes a touch and the CPU is completely consumed.  It seems that some code from the 4
.7.1 source did not get correctly ported to the Qt repository.
Since I have only tested on one "touch" platform, I suppose it could be platform-specfic - but be aware of this possible
 issue.
This app note:
has been updated for Qt repository version 4.8.2, reflecting some changes in the build process.
What is the the URL or the svn command to download Qt 4.8.2 for QNX ?
--Armin
> This app note:
> the build process.
Sorry, are you looking for pre-built?
To get source, AFAIK you have to use "git".
# git clone git://gitorious.org/qt/qt.git
Dennis,
sorry I didn't read your build documenation.
I'm just creatung a Linux installation of Momentics ...
Do you know the price (round about?) of a  pre-built version of digia?
--Armin
Is there one ?
> Qt General
> http://community.qnx.com/sf/go/post94492
> To cancel your subscription to this discussion, please e-mail general-qt-unsubscribe@community.qnx.com
Hi Dennis,
that's the result of my fist trial to recompile Qt 4.8.2 following your build docs:
make[1]: Entering directory `/root/qt1/qt/src/gui'
ntox86-g++ -c -include .pch/release-shared/QtGui -pipe -O2 -fvisibility=hidden -fvisibility-inlines-hidden -Wall -W -
D_REENTRANT -fPIC -DQT_SHARED -DQT_BUILD_GUI_LIB -DQT_NO_USING_NAMESPACE -DQT_NO_CAST_TO_ASCII -DQT_ASCII_CAST_WARNINGS
-DQT3_SUPPORT -DQT_MOC_COMPAT -DQT_USE_QSTRINGBUILDER -DQT_USE_BUNDLED_LIBPNG -DFT2_BUILD_LIBRARY -
DFT_CONFIG_OPTION_SYSTEM_ZLIB -DQT_NO_OPENTYPE -DQT_NO_STYLE_MAC -DQT_NO_STYLE_WINDOWSVISTA -DQT_NO_STYLE_WINDOWSXP -
DQT_NO_STYLE_WINDOWSCE -DQT_NO_STYLE_WINDOWSMOBILE -DQT_NO_STYLE_S60 -DQ_INTERNAL_QAPP_SRC -DQT_NO_DEBUG -DQT_CORE_LIB -
DQT_HAVE_MMX -DQT_HAVE_3DNOW -DQT_HAVE_SSE -DQT_HAVE_MMXEXT -DQT_HAVE_SSE2 -DQT_HAVE_SSE3 -DQT_HAVE_SSSE3 -
DQT_HAVE_SSE4_1 -DQT_HAVE_SSE4_2 -DQT_HAVE_AVX -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -I../../mkspecs/qws/qnx-i386-g+
+ -I. -I../../include/QtCore -I../../include -I../../include/QtGui -I.rcc/release-shared -I../3rdparty/xorg -Iimage -I..
/3rdparty/libpng -I../3rdparty/freetype/builds/unix -I../3rdparty/freetype/src -I../3rdparty/freetype/include -I../
3rdparty/harfbuzz/src -Idialogs -I.moc/release-shared -I.uic/release-shared -o .obj/release-shared/qapplication.o kernel
/qapplication.cpp
In file included from ../../include/QtGui/private/qt_x11_p.h:1,
                 from kernel/qapplication.cpp:82:
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:70:22: error: X11/Xlib.h: No such file or directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:75:23: error: X11/Xutil.h: No such file or directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:76:21: error: X11/Xos.h: No such file or directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:91:23: error: X11/Xatom.h: No such file or directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:98:36: error: X11/extensions/shape.h: No such file or
directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:103:37: error: X11/extensions/XInput.h: No such file or
directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:151:41: error: X11/extensions/Xinerama.h: No such file or
 directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:158:37: error: X11/extensions/Xrandr.h: No such file or
directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:163:38: error: X11/extensions/Xrender.h: No such file or
directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:168:35: error: X11/extensions/sync.h: No such file or
directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:174:26: error: X11/XKBlib.h: No such file or directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:218:33: error: X11/Xcursor/Xcursor.h: No such file or
directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:283:35: error: fontconfig/fontconfig.h: No such file or
directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:303:35: error: X11/extensions/XShm.h: No such file or
directory
../../include/QtGui/private/../../../src/gui/kernel/qt_x11_p.h:208: error: ISO C++ forbids declaration of 'Bool' with no
 type
What's wrong ?
--Armin
I did not build x86 with the "latest", so I did a fresh "git".  I got the same error you found.  Seems unnecessary to
build "x11" for x86 "embedded" but it does...
First I ran
# apt-get install libx11-dev
which installed /usr/lib/X11/Xlib.h .. and I thought everything would work after that.
However, it is still ignoring this file even though it is installed in the standard location...
Dennis,
this is working: see the attachment
--Armin
> First I ran
> Qt General
> http://community.qnx.com/sf/go/post94532
Attachment: Text config.status 451 bytes
Thanks Armin for pointing out the error in the 16-Jul-12 version of the document!
I have made corrections and replaced the online version with a 31-Jul-12 version...
Dennis,
I have tested qtEasy and ran:
#export QWS_DISPLAY=qnx
#export QWS_KEYBOARD=qnx
#export QWS_MOUSE_PROTO=qnx
# cEasy -qws
QQnxScreen: Attached to Device, number of displays: 1
QQnxScreen: Attached to Display 0, resolution 1280x1024, refresh 60 Hz
QQnxMouseHandler: connected.
QWSQnxKeyboardHandler: connected.
The graphics is OK  ... but mouse and keyboard are not working.
Is this the expected result ?
--Armin
PS: ph works if started from the telnet session ...
> Qt General
> http://community.qnx.com/sf/go/post94548
You have to manually start the following as on p7.
/usr/photon/bin/devi-hid -Pr kbd mouse
When you run "ph" to start photon, devi-hid is started automatically  (in a different mode).  For Qt, you must start it
yourself.
Yes ... I did it, but within the telnet session --> but no success.
When I run  "/usr/photon/bin/devi-hid -Pr kbd mouse &" locally on the QNX 6.5 machine ALL is working!
That means  ALL in demos and examples :)
--Armin
> different mode).  For Qt, you must start it yourself.
Interesting,  "/usr/photon/bin/devi-hid -Pr kbd mouse &" did work for me from telnet.  (You do have to start the Qt app
after you start devi-hid or it won't work...)
For me devi-hid is started in the bootscript - that works too.
Anyway, glad you got everything working!
Yes ... it works also for me. I started devi-hid as a "normal deamon"
process and not as a background process :)
--Armin
> (You do have to start the Qt app after you start devi-hid or
it won't work...)
> Qt General
> http://community.qnx.com/sf/go/post94591
