Re: Getting some assistance
06/16/2011 2:00 PM
post86685
Jim-
Have you checked the documentation on post20245 ? The QtEasy.pdf has a lot of details. But it assumes you install
the Qt development package on the target. Is that the issue - just looking to install on a target without a complete
development install?
(I am assuming X86 target - you didn't specify.)
>>>1. Can we have a complete list of libraries, binaries, scripts etc that have to be added to a standard OS install in
order to provide a Qt4 runtime environment.
The attachment contains a Qt application "cEasy". This is the list of libraries that cEasy requires to start.
Standard 6.5 install
libc.so.3
libstdc++.so.6
libm.so.2
libsocket.so.3
libgf.so.1
libz.so.2
Qt install into /usr/lib
libQtGui.so.4
libQtCore.so.4
QtDeclarative.so.4
libQtNetwork.so.4
libQtScript.so.4
libQtSvg.so.4
libQtSql.so.4
libQtXmlPatterns.so.4
a) I took a system without Qt installed, placed the above libraries in /usr/lib.
b) Set the three environment variables (see 4. below)
c) Untarred attachment to /qtEasy
d) Telneted in
e) Ran from telnet...
# /usr/photon/bin/devi-hid -Pr kbd mouse
f) From telnet direcory /qtEasy... ran
# ./cEasy -qws
Everything worked as expected - even on SVGA - with only the above steps.
>>>2. What services have to be running in order to accommodate a Qt4 executable? What I have been doing is to boot to a
command line screen i.e. everything except Photon. Is this correct?
Yes. From a # prompt, the system should be setup so "ph" correctly starts photon. BUT you must exit photon to start a
Qt app. (Photon is not necessary - only a test)
All you need to run a Qt app is a properly configued "gf" environment (graphics framework). A CD-install of SDP 6.5 has
"gf" already setup. A test of gf (for i830 - not vesa/svga) is that vsync should run and display on screen. (Also, "
vsync 2" and "vsync 3") You can even run "vsync 2" while a Qt app is running - vsync will overlay.
>>>3. I understand that not all graphics drivers will support Qt4. We are using the i830 driver. Will the 6.5.0 issued
driver work with Qt or do we need to use a later development version?
Yes. I use devg-gma9xx.so "out of the box". Actually, any "gf" driver should work since Qt only requires one layer -
even SVGA. Qt uses only a "framebuffer" approach.
io-display requires libffb.so.2 in addition to driver, libc and libm.
4. What environment variables are required for Qt applications?
export QWS_DISPLAY=qnx
export QWS_KEYBOARD=qnx
export QWS_MOUSE_PROTO=qnx
>>>5. Are you able to provide a trivial, stand alone Qt4 app that can be used to verify the run-time setup. (The medical
demo is too complex).
Agreed. That is why I created port20245 and post20394. The attachment to this post contains the runtime components
from the first project.
Dennis
