Forum Topic - unable to execute qtdemo: (12 Items)
I followed the instruction and tried to execute qtdemo binary directly on target. The target is qnx 6.5 running on
vmware esxi server.
when executing qtdemo -qws, the following message showed:
QQnxScreen: attached to device, number of display: 1
QQnxScreen: attached to Display 0, resolution 1024x768, refresh 60 Hz.
QQnxScreen: gf_layer_attach(0) failed with error code 0
qnx: driver cannot connect
Abort(core dump)
I was able to login qnx with photon/phindow, io-graphic and io-display are also launched. if there's anything else I
need to configure? or anyone run on top of vm?
thanks
-Frank
Re: unable to execute qtdemo
Sounds like photon is running when you launch qtdemo?  You must exit photon and launch qtdemo from a text prompt.
Dennis
I'm new to qt/qnx.
 how do i leave photon but still see qtdemo? i assumed it will generate ui/window.
does it mean that I just need to slay photon?
1) Launch button/Logout/End Photon session ... will exit photon to text mode.
2) Login.  Run "ifconfig" and determine IP address.
3) Telnet into the IP address from a different host.
4)  From telnet, run  '/usr/photon/bin/devi-hid -Pr kbd mouse'
5) From telnet, run 'qtdemo -qws' ...  graphics should appear on console
I follow the steps , but the mouse and keyboard  no response.
i got qtdemo -qws working and saw the main window.
i followed the instruction to load mouse/keyboard but still no response.
cool! it works! thanks
By the way, why i cannot see openGL example from it? in window qt creator, there's demo for openGL.
how can you get success?i follow the steps ,but fail,can you explain it to me ,thank you
It is also worth running in verbose mode to start with. I could not get the mouse to respond. FYI - I was not actually
using the keyboard at the time.  After running in verbose mode I got the following output:
# slay devi-hid
# /usr/photon/bin/devi-hid -v -Pr kbd mouse
Looking up kbd in module table
Looking up mouse in module table
Cannot open trap file /etc/system/trap/devi-rel-opts (No such file or directory)
Resetting module mouse
Resetting module rel
Resetting module kbd
Resetting module keyboard
Process home directory is /usr/photon/bin/
Try to open keyboard descriptor ( /etc/system/trap/.KEYBOARD)
Try to open keyboard descriptor ( /etc/system/trap/.KEYBOARD.localhost)
Try to load default keyboard
Load default keymap file (/usr/photon/bin/en_US_101.kbd)
Opening keyboard file: /usr/photon/bin/en_US_101.kbd
Error: file /usr/photon/bin/en_US_101.kbd - No such file or directory; cannot load keymap file
Opening keyboard file: /usr/photon/keyboard/en_US_101.kbd
Switch to keyboard /usr/photon/keyboard/en_US_101.kbd
Input:#  starting non Photon interface
*** I then removed the 'kbd' parameter and then the mouse worked:
# slay devi-hid
# /usr/photon/bin/devi-hid -v -Pr mouse
I had the same problem. With this thread, I started QNX without photon and started the qtdemo with telnet.
But I still get the following error:
QQnxScreen: Attached to Device, number of displays: 1
QQnxScreen: Attached to Display 0, resolution 1152x864, refresh 60 Hz
Am I still missing something? Could it be because I'm using QNX in a Virtual Machine (with Virtual Box)?
- Magdalena
>>> Could it be because I'm using QNX with Virtual Box?
That is a possiiblity.  Qt works with VMware and the QNX-supplied image.
Thank you for your quick answer!
Must have missed it yesterday, but now I found the answer in another thread (post89523): the color mode had to be set to
 64K, and it works!
After all, the QNX image and Qt work with VirtualBox, too.
Magdalena
