QNX 4.25 2015 Experimental USB
02/10/2021 4:07 AM
post121251
Hello. I have a miniPC Jetway FHP792x , which has only USB ports. I manage to install the experimental product suite
2015, the usb keyboard works in the installer just fine. After that i manage to make the usb keyboard work with the "
Input kbd -R fd -d / dev / usbkbd0" in sysinit. But if i want to start the io-usb the PC freezes.
Is there a bypass or a fix for this?
Thank you very much!
Re: QNX 4.25 2015 Experimental USB
02/12/2021 12:50 AM
post121256
I think, it might cause by usb 3.0 stack.
You should enter BIOS > CPU config > South Bridge . And, disable USB 3.0 or XHCI. Then check again.
02/12/2021 4:02 AM
post121257
Hello Voicu,
Have you enabled USB support in boot menu while installing from experimental CD? Or have you used USB legacy?
> install the experimental product suite 2015, the usb keyboard works in the
> the " Input kbd -R fd -d / dev / usbkbd0" in sysinit. But if i want to start
02/12/2021 4:30 AM
post121258
Hello , and thanks for the replies.
USB Legacy its ENABLED in BIOS , and i activated the USB Stack from the Experimental CD (because i am installing from an
USB DVD RW).
If i take out the io-usb from sysinit the keyboard works fine.
If i run the io-usb from command line, it recognizes the USB DVDRW, and after that the keyboard freeezes.
02/24/2021 4:29 AM
post121291
Hello Voicu,
Sorry for the delay with my answer. USB keyboard is not supported in console mode. You have to launch Photon to use USB
keyboard. If you need console to work properly, then you can launch io-usb-ehci instead of io-usb to work with EHCI
controllers (mostly mass storage devices).
> Experimental CD (because i am installing from an USB DVD RW).
03/10/2021 7:14 AM
post121323
Maybe it is different in combination with Photon, but for our QNX Windows based system USB keyboard works in console
mode as well. We start it using these commands:
io-usb
devu-kbd
Dev32.ansi -Q -n 6 -d/dev/usbkbd0
/Christian
04/06/2021 2:29 AM
post121365
I will try and let you know. Thanks for the replies.
04/06/2021 4:13 AM
post121366
Here is my sysinit
#image: /boot/sys/boot -v
#image:/boot/sys/Proce32 -E0 -| 2
#image:/boot/sys/Slib32
#image:/boot/sys/Slib16
#image:/bin/Fsys -Hdisk160
#image:/bin/Fsys.ahci fsys -Ndsk1 -n0=hd1. -n5=cd1.
#image:/bin/mount -p /dev/hd1.0 /dev/hd1.0t77 /
#image:/bin/sinit TERM=qnxm
#export NODE=2
export KBD=en_CA_101.kbd
export ABLANG=en
export CON_KBD=USA
export TZ=est05edt04,M4.1.0/2,M10.5.0/2
/bin/rtc -| hw
Dev &
emu87 &
Pipe &
/bin/Dev.ser -N/dev/ser1 3f8,4 &
/bin/Dev.ser -N/dev/ser1 2f8,3 &
Dev.ansi -Q -n6 &
reopen /dev/con1
kbd $CON_KBD
prefix -A/dev/console=/dev/con1
Dev.pty &
Dev.pty -n16 &
io-usb
/bin/Fsys.umass fsys -Ndsk2 -n0=hd2. -n5=cd2.
Iso9660fsys /cd2.0=/dev/cd2.0 &
#Define the default CD Rom
/bin/prefix -A /cd=//0/cd2.0
nameloc &
chkfsys /
if test -f /etc/config/bin/tcpip.$NODE
then
/etc/config/bin/ph.$NODE
else
tinit -t/dev/con1 &
tinit -T/dev/con2[2-6] &
fi
04/06/2021 4:14 AM
post121367
> Here is my sysinit
> #export NODE=2
> export ABLANG=en
> export CON_KBD=USA
> /bin/rtc -| hw
> Dev &
> emu87 &
> Pipe &
> Dev.ansi -Q -n6 &
> reopen /dev/
con1
> kbd $CON_KBD
> Dev.pty &
> Dev.pty -n16 &
> io-usb
> nameloc &
> chkfsys /
> then
> else
> tinit -t/dev/con1 &
> fi
If i take out the io-usb the keyboard works , else it freezes.
04/07/2021 4:39 AM
post121370
Hi Voicu,
Dev.ansi should have -d option to support USB keyboard. Please check use Dev.ansi for that. To use native (not in USB
legacy mode) USB keyboard in console you have to add (or replace existing ones) lines in specified order (usually add io
-usb and devu-kbd just before the Dev.ansi) to you /etc/config/sysinit.N file:
io-usb
devu-kbd
Dev.ansi -Q -n6 -d /dev/usbkbd0 &
Additionally adding sleep 1, sleep 2 or so on may be required to be sure that io-usb and devu-kbd are both started and initialized before the launching of Dev.ansi.
The -d option is significant here. Also if you launch io-usb and devu-kbd after the Dev.ansi without -d option then the keyboard will leave the USB legacy mode and stop to working.
> > Here is my sysinit
> > #export NODE=2
> > export ABLANG=en
> > export CON_KBD=USA
> > /bin/rtc -| hw
> > Dev &
> > emu87 &
> > Pipe &
> > Dev.ansi -Q -n6 &
reopen /dev/con1
> > kbd $CON_KBD
> > Dev.pty &
> > Dev.pty -n16 &
> > io-usb
> > nameloc &
> > chkfsys /
> > then
> > else
> > tinit -t/dev/con1 &
> > fi
04/20/2021 4:32 PM
post121383
You mean that my sysinit should look like this ?
#export NODE=2
export ABLANG=en
export CON_KBD=USA
/bin/rtc -| hw
Dev &
emu87 &
Pipe &
io-usb
devu-kbd
reopen /dev/con1
kbd $CON_KBD
Dev.pty &
Dev.pty -n16 &
io-usb
nameloc &
chkfsys /
then
else
tinit -t/dev/con1 &
fi
04/21/2021 4:27 AM
post121384
Hi Voicu,
Yes, I meant something like this.
I see that you launch io-usb twice. Remove second io-usb (before Fsys.umass).
> #export NODE=2
> export ABLANG=en
> export CON_KBD=USA
> /bin/rtc -| hw
> Dev &
> emu87 &
> Pipe &
> io-usb
> devu-kbd
> reopen /dev/con1
> kbd $CON_KBD
> Dev.pty &
> Dev.pty -n16 &
> io-usb
> nameloc &
> chkfsys /
> then
> else
> tinit -t/dev/con1 &
> fi
04/22/2021 3:10 AM
post121386
Hey thanks for the solution, it worked. I have one more question .
If i want to attach an USB - Floppy Disk what do i have to write in the sysinit ?
Thanks!!!!
04/22/2021 5:05 AM
post121387
Hi Voicu,
Fsys.umass should support USB floppy devices.
> sysinit ?
> Thanks!!!!
07/01/2021 9:36 AM
post121477
Hello dear Oleg!
I have another issue.
I need to create a ramdisk /dev/ram but when i try it the system boots and hangs.
i write
/BIN/FSYS
$ Fsys -Hdisk160 -r
and it doesnt work.
On the old hardware that doesnt work anymore the line was
/BIN/FSYS
$ Fsys -r 500
dinit /dev/ram /ram
and it worked. (The old hardware had IDE HDD)
This one has a CF.
What should i do ?
07/01/2021 9:49 AM
post121478
Hi Voicu,
It looks like you have forgotten to specify argument for -r option.
> Hello dear Oleg!
> hangs.
> i write
> /BIN/FSYS
> $ Fsys -Hdisk160 -r
> and it doesnt work.
> /BIN/FSYS
> $ Fsys -r 500
> dinit /dev/ram /ram
> This one has a CF.
> What should i do ?
07/01/2021 4:33 PM
post121479
I forgot to mention in the post that i wrote -r 500 like it was on the old hardware. (on the old hardware it created the
/dev/ram /ram and it worked)
Should i use another value?
07/02/2021 3:16 AM
post121481
Long story short is i need to make a ramdisk called /ram.
What lines and where do i have to write to make it work ?
07/02/2021 5:12 AM
post121482
Hi Voicu,
You can use Fsys's -r option to create RAM-disk. If it doesn't work then post here the output of command.
Also you can use Efsys.ram to create embedded filesystem on ram disk.
07/02/2021 6:37 AM
post121483
I understand , but where do i have to write the Fsys -r command?
I tried like this.
i edited the install.2 of the pc, and added the line
/bin/Fsys
$ Fsys -r 500
then i compiled the file with make b=install.2
i copied the install.2 as .altboot , so it wouldnt mess with the original boot
And i get the error that Fsys resource busy
07/02/2021 6:48 AM
post121484
Fsys failed to attach name: resource busy.
And this is the content of my install.2
/boot/sys/boot
$ /boot/sys/boot -v
/boot/sys/Proc32
$ /boot/sys/Proc32 -E0 - l 2
/boot/sys/Slib32
$ /boot/sys/Slib32
/boot/sys/Slib16
$ /boot/sys/Slib16
/bin/Fsys
$ /bin/Fsys -r 500
/bin/Fsys
$ /bin/Fsys -Hdisk160
/bin/Fsys.ahci
$ /bin/Fsys.ahci fsys -Ndsk1 -n0=hd1. -n5=cd1.
/bin/mount
$ /bin/mount -p /dev/hd1.0 /dev/hd1.0t77 /
/bin/sinit
$ /bin/sinit TERM=qnxm
07/02/2021 6:52 AM
post121486
It should be:
/bin/Fsys
$ /bin/Fsys -Hdisk160 -r500
> /boot/sys/boot
> $ /boot/sys/boot -v
> /boot/sys/Proc32
> /boot/sys/Slib32
> $ /boot/sys/Slib32
> /boot/sys/Slib16
> $ /boot/sys/Slib16
> /bin/Fsys
> $ /bin/Fsys -r 500
> /bin/Fsys
> /bin/Fsys.ahci
> /bin/mount
> /bin/sinit
07/02/2021 6:51 AM
post121485
Voicu,
Do not launch Fsys twice. You have to add desired options to the single Fsys line.
> I tried like this.
> /bin/Fsys
> $ Fsys -r 500
07/02/2021 12:31 PM
post121489
/bin/Fsys
I made a mistake then , cause i wrote it like that but i put a space between -r and 500
So the correct form is $ /bin/Fsys -Hdisk160 -r500 or $ /bin/Fsys -Hdisk160 -r 500 ?
07/05/2021 1:45 AM
post121492
If i write on the same line with -Hdisk160 -r500 the system hangs
