Forum Topic - USB driver/Stack Bug upon driver slaying:
Hi Guys,
There is a bug within either the devu-* class drivers or within io-usb, where if the driver are are started and then
slayed off, then the device no longer appears on the bus.  This only appears to effect the class drivers devu-* (kbd/
mouse/etc).
E.g.
# usb
USB 0 (EHCI) v1.10, v1.01 DDK, v1.01 HCD
USB 1 (OHCI) v1.10, v1.01 DDK, v1.01 HCD
Device Address             : 1
Vendor                     : 0x045e (Microsoft)
Product                    : 0x0039 (Microsoft 5-Button Mouse with IntelliEye(TM))
Class                      : 0x00 (Independant per interface)
# devu-mouse
# ls /dev/usbmouse0
/dev/usbmouse0
# Input msoft fd -d /dev/usbmouse0 &
%1 +  4851 Running              Input msoft fd -d /dev/usbmouse0
Move the mouse a bit
# slay Input
slay: //1/bin/Input 4851 on //1/dev/ttyp4 (y/N)? Y
slay: //1/bin/Input 4853 on //1/dev/ttyp4 (y/N)? Y
%1    4851 Done                 Input msoft fd -d /dev/usbmouse0
# usb
Device Address             : 1
# slay devu-mouse
slay: //1/bin/devu-mouse 4636 on //1/dev/ttyp4 (y/N)? Y
slay: //1/bin/devu-mouse 22562 on //1/dev/ttyp4 (y/N)? Y
# usb
device 1 - descriptors - Input/output error                   <----------------------- ooops.
# slay io-usb
# io-usb
# usb
Device Address             : 1
slaying io-usb or removing the device fixes the issue and the device will re-appear.  I suspect that the issue is within
 the signal handler of the class drivers and they are not cleaning up properly and leaving io-usb in a goofy state.
Hoping you guys can figure it out.
Best regards,
Erick
Re: USB driver/Stack Bug upon driver slaying
I should note that this does *not* happen on QNX6, however those are different drivers
Hi Erick,
What version of io-usb do you use? We should reproduce this issue to find a solution.
> 26 февр. 2015 г., в 19:57, Erick Muis <community-noreply@qnx.com> написал(а):
> Hi Guys,
mouse/etc).
> E.g.
> # usb
> Device Address             : 1
> # devu-mouse
> # ls /dev/usbmouse0
> /dev/usbmouse0
> # slay Input
> # usb
> Device Address             : 1
> # slay devu-mouse
> # usb
> # slay io-usb
> # io-usb
> # usb
> Device Address             : 1
within the signal handler of the class drivers and they are not cleaning up properly and leaving io-usb in a goofy state
> Best regards,
> Erick
> http://community.qnx.com/sf/go/post113382
Hi Oleg
It's the latest from the file releases in the myQNX download section.
Built 2013, although any version seem to reproduce the issue. I'm on my phone so I can't get the exact version number.
Best regards,
Erick
> Hi Erick,
> solution.
> Respectfully,
> Oleg
> > Hi Guys,
> where if the driver are are started and then slayed off, then the device no
> -* (kbd/mouse/etc).
> > E.g.
> > # usb
> > Device Address             : 1
> IntelliEye(TM))
> > # devu-mouse
> > # ls /dev/usbmouse0
> > /dev/usbmouse0
> > # slay Input
> > # usb
> > Device Address             : 1
> IntelliEye(TM))
> > # slay devu-mouse
> > # usb
> > # slay io-usb
> > # io-usb
> > # usb
> > Device Address             : 1
> IntelliEye(TM))
> -appear.  I suspect that the issue is within the signal handler of the class
> state.
> > Best regards,
> > Erick
> > General
Hi Erick,
We can not yet reproduce the issue. What are your computer model (or mainboard) and mouse type. Did you try another
mouse type? Please send me output of following commands before the issue occurs:
# sin ver
# sin info
# sin ar
# sin mem
And output of sin mem after the issue happens.
It may the issue occurs because of lack of free GDTs. Can you check this guess? Add -S 6600 1000 option to Proc32 and
build boot image. After this repeat your procedure. Has system behavior changed with the -S option?
27 февр. 2015 г., в 3:47:56, Erick Muis <community-noreply@qnx.com> написал:
> Hi Oleg
> Best regards,
> Erick
>> Hi Erick,
>> solution.
>> Respectfully,
>> Oleg
>>> Hi Guys,
>> -* (kbd/mouse/etc).
>>> E.g.
>>> # usb
>>> Device Address             : 1
>> IntelliEye(TM))
>>> # devu-mouse
>>> # ls /dev/usbmouse0
>>> /dev/usbmouse0
>>> # slay Input
>>> # usb
>>> Device Address             : 1
>> IntelliEye(TM))
>>> # slay devu-mouse
>>> # usb
>>> # slay io-usb
>>> # io-usb
>>> # usb
>>> Device Address             : 1
Hi Oleg,
It appears to be isolated to Vmware, as I was not able to reproduce it on a real PC.
For good measure I attached the output from the utils, and it still did happen after increasing the number of global and
 local segments :(
Best regards,
Erick
> Hi Erick,
> mainboard) and mouse type. Did you try another mouse type? Please send me
> # sin ver
> # sin info
> # sin ar
> # sin mem
> ? Add -S 6600 1000 option to Proc32 and build boot image. After this repeat
> Respectfully,
> Oleg
> > Hi Oleg
> > Best regards,
> > Erick
> >> Hi Erick,
> >> solution.
> >> Respectfully,
> >> Oleg
> >>> Hi Guys,
> devu
> >> -* (kbd/mouse/etc).
> >>> E.g.
> >>> # usb
> >>> Device Address             : 1
> >> IntelliEye(TM))
> >>> # devu-mouse
> >>> # ls /dev/usbmouse0
> >>> /dev/usbmouse0
> >>> # slay Input
> >>> # usb
> >>> Device Address             : 1
> >> IntelliEye(TM))
> >>> # slay devu-mouse
> >>> slay: //1/bin/devu-mouse 22562...
Attachment: Text QNX4_usb_bug.txt 20.02 KB
Hi Erick,
Reproducing the issue under VMWare was the first what has been tried. Unfortunately, the issue is not reproduced under
VMWare Workstation 9 Linux host. What version of VMWare do you use? Can you send me *.vmx file from your VMWare folder?
28 февр. 2015 г., в 2:06:29, Erick Muis <community-noreply@qnx.com> написал:
> Hi Oleg,
and local segments :(
> Best regards,
> Erick
>> Hi Erick,
>> # sin ver
>> # sin info
>> # sin ar
>> # sin mem
>> Respectfully,
>> Oleg
>>> Hi Oleg
>>> Best regards,
>>> Erick
>>>> Hi Erick,
>>>> solution.
>>>> Respectfully,
>>>> Oleg
>>>>> Hi Guys,
>> devu
>>>> -* (kbd/mouse/etc).
>>>>> E.g.
>>>>> # usb
>>>>> Device Address             : 1
>>>> IntelliEye(TM))
>>>>> # devu-mouse
>>>>> # ls /dev/usbmouse0
>>>>> /dev/usbmouse0
>>>>> # slay Input
>>>>> %1    4851 Done                 Input msoft fd -d /dev/usbmouse0...
Hi Oleg,
Sigh, my bad, sorry, this is VirtualBox, not Vmware.  I don't have a VMware virtual machine at this time to test,
however if you guys can't reproduce it, it must be isolated to VirtualBox.  Good enough reason for me to move to VMware
proper :)
Thanks for the help.
Best regards,
Erick
> Hi Erick,
> Unfortunately, the issue is not reproduced under VMWare Workstation 9 Linux
> VMWare folder?
> Respectfully,
> Oleg
> > Hi Oleg,
> real PC.
> happen after increasing the number of global and local segments :(
> > Best regards,
> > Erick
> >> Hi Erick,
> >> # sin ver
> >> # sin info
> >> # sin ar
> >> # sin mem
> guess
> >> Respectfully,
> >> Oleg
> >>> Hi Oleg
> >>> Best regards,
> >>> Erick
> >>>> Hi Erick,
>  a
> >>>> solution.
> >>>> Respectfully,
> >>>> Oleg
> >>>>> Hi Guys,
> no
> >> devu
> >>>> -* (kbd/mouse/etc).
> >>>>> E.g.
> >>>>> # usb
> >>>>> Device Address             : 1
Hi Erick,
We’ll test the issue under VirtualBox. What version of VirtualBox do you use?
5 марта 2015 г., в 20:15, Erick Muis <community-noreply@qnx.com> написал:
> Hi Oleg,
proper :)
> Best regards,
> Erick
>> Hi Erick,
>> VMWare folder?
>> Respectfully,
>> Oleg
>>> Hi Oleg,
>> real PC.
>>> Best regards,
>>> Erick
>>>> Hi Erick,
>>>> # sin ver
>>>> # sin info
>>>> # sin ar
>>>> # sin mem
>> guess
>>>> Respectfully,
>>>> Oleg
>>>>> Hi Oleg
>>>>> Best regards,
>>>>> Erick
>>>>>> Hi Erick,
>> a
>>>>>> solution.
>>>>>> Respectfully,
>>>>>> Oleg
>>>>>>> Hi Guys,
>> no
>>>> devu
>>>>>> -* (kbd/mouse/etc).
Hi Oleg,
I have 4.1.12_Ubuntu R77245
Thanks!
Erick
> Hi Erick,
> Respectfully,
> Oleg
> > Hi Oleg,
> virtual machine at this time to test, however if you guys can't reproduce it,
> VMware proper :)
> > Best regards,
> > Erick
> >> Hi Erick,
> your
> >> VMWare folder?
> >> Respectfully,
> >> Oleg
> >>> Hi Oleg,
> a
> >> real PC.
> >>> Best regards,
> >>> Erick
> >>>> Hi Erick,
> >>>> # sin ver
> >>>> # sin info
> >>>> # sin ar
> >>>> # sin mem
> >> guess
> repeat
> >>>> Respectfully,
> >>>> Oleg
> >>>>> Hi Oleg
> >>>>> Best regards,
> >>>>> Erick
> >>>>>> Hi Erick,
> find
> >> a
> >>>>>> solution.
> >>>>>> Respectfully,
> >>>>>> Oleg
> >>>>>>> 26 февр. 2015 г., в 19:57, Erick Muis...
Hi Erick,
We’ve reproduced the issue, but additional testing is required to determine the cause of this behavior.
5 марта 2015 г., в 20:39, Erick Muis <community-noreply@qnx.com> написал:
> Hi Oleg,
> Thanks!
> Erick
>> Hi Erick,
>> Respectfully,
>> Oleg
>>> Hi Oleg,
>> VMware proper :)
>>> Best regards,
>>> Erick
>>>> Hi Erick,
>> your
>>>> VMWare folder?
>>>> Respectfully,
>>>> Oleg
>>>>> Hi Oleg,
>> a
>>>> real PC.
>>>>> Best regards,
>>>>> Erick
>>>>>> Hi Erick,
>>>>>> # sin ver
>>>>>> # sin info
>>>>>> # sin ar
>>>>>> # sin mem
>>>> guess
>> repeat
>>>>>> Respectfully,
>>>>>> Oleg
>>>>>>> Hi Oleg
>>>>>>> Best...
Hi Erick,
As a result of our additional testing I can say that the issue associated with the specifics of VirtualBox. Fixing it in
 QNX4 is time-consuming work.
5 марта 2015 г., в 20:39:22, Erick Muis <community-noreply@qnx.com> написал:
> Hi Oleg,
> Thanks!
> Erick
>> Hi Erick,
>> Respectfully,
>> Oleg
>>> Hi Oleg,
>> VMware proper :)
>>> Best regards,
>>> Erick
>>>> Hi Erick,
>> your
>>>> VMWare folder?
>>>> Respectfully,
>>>> Oleg
>>>>> Hi Oleg,
>> a
>>>> real PC.
>>>>> Best regards,
>>>>> Erick
>>>>>> Hi Erick,
>>>>>> # sin ver
>>>>>> # sin info
>>>>>> # sin ar
>>>>>> # sin mem
>>>> guess
>> repeat
>>>>>> Respectfully,
>>>>>> Oleg
>>>>>>> Hi Oleg
RE: USB driver/Stack Bug upon driver slaying
Oleg,
Can you give us the details on what you found?  Where the fix would need to be made?  What else it might affect?  If
it's just a problem in VirtualBox, then I'm not too concerned...
-Martin.
From: Олег Большаков [mailto:community-noreply@qnx.com]
Sent: March-12-15 7:36 AM
To: general-qnx4@community.qnx.com
Subject: Re: USB driver/Stack Bug upon driver slaying
Hi Erick,
> Hi Oleg,
> Thanks!
> Erick
>> Hi Erick,
>> Respectfully,
>> Oleg
>>> Hi Oleg,
>>> VMware
>> for me to move to VMware proper :)
>>> Best regards,
>>> Erick
>>>> Hi Erick,
>>>> 9 Linux
>>>> from
>> your
>>>> VMWare folder?
>>>> Respectfully,
>>>> Oleg
>>>>> Hi Oleg,
>>>>> reproduce it on
>> a
>>>> real PC.
>>>>> still did
>>>>> Best regards,
>>>>> Erick
>>>>>> Hi Erick,
>>>>>> (or
>>>>>> send me
>>>>>> # sin ver
>>>>>> # sin info
>>>>>> # sin ar
>>>>>> # sin mem
>>>>>> check this
>>>> guess
>>>>>> this
>> repeat
>>>>>> Respectfully,
Hi Martin,
This issue occurs in VirtualBox only. We performed Erick's routine sequentially several times to reproduce it. Also we
can't reproduce the issue with all available OHCI USB controllers. Looking how strange VirtualBox works with USB devices
, I guess it should be a problem of VirtualBox. We can fix it if required, but it takes some time.
12 марта 2015 г., в 16:31:36, Martin Walter <community-noreply@qnx.com> написал:
> Oleg,
> -Martin.
> Hi Erick,
in QNX4 is time-consuming work.
> Respectfully,
> Oleg
>> Hi Oleg,
>> Thanks!
>> Erick
>>> Hi Erick,
>>> Respectfully,
>>> Oleg
>>>> Hi Oleg,
>>>> VMware
>>>> Best regards,
>>>> Erick
>>>>> Hi Erick,
>>>>> 9 Linux
>>>>> from
>>> your
>>>>> VMWare folder?
>>>>> Respectfully,
>>>>> Oleg
>>>>>> Hi Oleg,
>>>>>> reproduce it on
>>> a
>>>>> real PC.
>>>>>> still did
>>>>>> Best regards,
>>>>>> Erick
>>>>>>> Hi Erick,
>>>>>>> (or
>>>>>>> send me
Don't spend any more time on this.
Thanks...Martin.
Sent: March-12-15 10:31 AM
Hi Martin,
> Oleg,
> -Martin.
> Hi Erick,
> Respectfully,
> Oleg
>> Hi Oleg,
>> Thanks!
>> Erick
>>> Hi Erick,
>>> Respectfully,
>>> Oleg
>>>> Hi Oleg,
>>>> a VMware
>>>> Best regards,
>>>> Erick
>>>>> Hi Erick,
>>>>> Workstation
>>>>> 9 Linux
>>>>> file from
>>> your
>>>>> VMWare folder?
>>>>> Respectfully,
>>>>> Oleg
>>>>>> Hi Oleg,
>>>>>> reproduce it on
>>> a
>>>>> real PC.
>>>>>> still did
>>>>>> Best regards,
>>>>>> Erick
>>>>>>> Hi Erick,
