Re: QNX v4 Suite 2009, USB stack from Suite 2011, total freeze
01/20/2015 6:10 AM
post113005
Hi Zbigniew,
> 2. I did run the HP Vision (HW) Diagnostics and the computer passed it. What HW tests are you talking about?
I meant any HW tests that you can run to check HW. :)
> Could you explain why using the output to COM port would be beneficial in troubleshooting this failure.
I guess that you can't see all diagnostic output when you use QNX Windows. So I suggested you use COM port for the
diagnostics.
> Just before the freeze, there are some (our add-on software) log entries showing that the system is busy...
What did you mean when you wrote that the system is busy? Can you collect some system information (sin ar, sin ver, sin
ir, sin ti, sin pr) just before the freeze?
19 янв. 2015 г., в 16:49:00, Zbigniew Kazmierczak <community-noreply@qnx.com> написал:
> Oleg,
> Here are answers to your questions:
> 1. I have only one HP z230 PC to test, so no comparison possible.
> 3. The (only available) COM port is being used for data communications as part of the test. I'd rather not use it for
Proc output.
> Pls note that computer runs for hours without showing any signs of problems. Just before the freeze, there are some
(our add-on software) log entries showing that the system is busy... This is the first time (while using QNX 4 for over
20 years) that I experience such a total failure that prevents me from narrowing and finding the cause. Could you
> http://community.qnx.com/sf/go/post112994
