Forum Topic - Advantech IPC-610H:
Advantech IPC-610H
We have purchased an Advantech IPC-610H unit and have loaded QNX4.25 using the 2011 Product suite.
We are having a problem with the graphics driver.
From show_pci:
PCI version    = 3.00
Vendor ID      = 8086h, INTEL CORPORATION
Device ID      = 29b2h,
PCI index      = 0h
                 MEM @ fea80000h IO @ dc00h MEM @ d0000000h MEM @ fe900000h
PCI Int Pin    = INT A
Interrupt line = 10
Does anyone have any ideas?
Pete Mackereth
Re: Advantech IPC-610H
Hi Pete,
What kind of problem do you have? What driver do you try? Intel Q35 (8086h:29b2h) should be supported by Pg.i810 and Pg.
i915.
> 2 янв. 2015 г., в 19:43, Pete Mackereth <community-noreply@qnx.com> написал:
> Hello,
> From show_pci:
> PCI version    = 3.00
> Device ID      = 29b2h,
> PCI index      = 0h
> PCI Int Pin    = INT A
> Interrupt line = 10
> Thanks,
> Pete Mackereth
> http://community.qnx.com/sf/go/post112804
RE: Advantech IPC-610H
Hi Oleg,
Did you get the chance to look at the Pg.i830 driver for the 29b2h, I am still having problems.
Pete
From: Олег Большаков [mailto:community-noreply@qnx.com]
Sent: 02 January 2015 18:07
To: general-qnx4@community.qnx.com
Subject: Re: Advantech IPC-610H
Hi Pete,
i915.
> Hello,
> From show_pci:
> PCI version    = 3.00
> Device ID      = 29b2h,
> PCI index      = 0h
> PCI Int Pin    = INT A
> Interrupt line = 10
> Thanks,
> Pete Mackereth
General
http://community.qnx.com/sf/go/post112805
Hi Pete,
Sorry for the delay with my answer. I've noticed that you tested only 8-bit colour modes with Pg.i830. Try 32-bit mode.
To do this place 32-bit mode line at the top of crt.$NODE, restart the PC and launch ph script. Try different modes like
 800x600x32, 1024x768x32, etc. Don't forget to place each line at the top of your crt.$NODE and restart the PC before
launch ph to perform neat testing.
12 янв. 2015 г., в 15:31:23, Pete Mackereth <community-noreply@qnx.com> написал:
> Hi Oleg,
> Regards,
> Pete
> Hi Pete,
Pg.i915.
> Respectfully,
> Oleg
>> Hello,
>> From show_pci:
>> PCI version    = 3.00
>> Device ID      = 29b2h,
>> PCI index      = 0h
>> PCI Int Pin    = INT A
>> Interrupt line = 10
>> Thanks,
>> Pete Mackereth
>> General
> http://community.qnx.com/sf/go/post112903
Hi Oleg,
That's done the trick, thank you!
Pete
Sent: 12 January 2015 12:31
Hi Pete,
> Hi Oleg,
> Regards,
> Pete
> Hi Pete,
Pg.i915.
> Respectfully,
> Oleg
>> Hello,
>> From show_pci:
>> PCI version    = 3.00
>> Device ID      = 29b2h,
>> PCI index      = 0h
>> PCI Int Pin    = INT A
>> Interrupt line = 10
>> Thanks,
>> Pete Mackereth
>> General
General
http://community.qnx.com/sf/go/post112904
Pete,
I'm glad to hear that your problem has been solved. Can you also try 32-bit modes with Pg.i915?
12 янв. 2015 г., в 16:42:37, Pete Mackereth <community-noreply@qnx.com> написал:
> Hi Oleg,
> Regards,
> Pete
> Hi Pete,
. To do this place 32-bit mode line at the top of crt.$NODE, restart the PC and launch ph script. Try different modes
like 800x600x32, 1024x768x32, etc. Don't forget to place each line at the top of your crt.$NODE and restart the PC
before launch ph to perform neat testing.
> Respectfully,
> Oleg
>> Hi Oleg,
>> Regards,
>> Pete
>> -----Original Message-----
>> Hi Pete,
Pg.i915.
>> Respectfully,
>> Oleg
>>> Hello,
>>> From show_pci:
>>> PCI version    = 3.00
>>> Device ID      = 29b2h,
>>> PCI index      = 0h
>>> PCI Int Pin    = INT A
>>> Interrupt line = 10
>>> Thanks,
>>> Pete Mackereth
>>> General
>> General
>> General
Hi Oleg,
Pg.i915 also works at 1024x768x32.
Pete
Sent: 12 January 2015 13:06
Pete,
> Hi Oleg,
> Regards,
> Pete
> Hi Pete,
> Respectfully,
> Oleg
>> Hi Oleg,
>> Regards,
>> Pete
>> Hi Pete,
Pg.i915.
>> Respectfully,
>> Oleg
>>> Hello,
>>> From show_pci:
>>> PCI version    = 3.00
>>> Device ID      = 29b2h,
>>> PCI index      = 0h
>>> PCI Int Pin    = INT A
>>> Interrupt line = 10
>>> Thanks,
>>> Pete Mackereth
>>> General
>> General
>> General
Thank you.
13 янв. 2015 г., в 20:46:58, Pete Mackereth <community-noreply@qnx.com> написал:
> Hi Oleg,
> Regards,
> Pete
> Pete,
> Respectfully,
> Oleg
>> Hi Oleg,
>> Regards,
>> Pete
>> Hi Pete,
mode. To do this place 32-bit mode line at the top of crt.$NODE, restart the PC and launch ph script. Try different
modes like 800x600x32, 1024x768x32, etc. Don't forget to place each line at the top of your crt.$NODE and restart the PC
>> Respectfully,
>> Oleg
>>> Hi Oleg,
>>> Regards,
>>> Pete
>>> Hi Pete,
 Pg.i915.
>>> Respectfully,
>>> Oleg
>>>> Hello,
>>>> From show_pci:
>>>> PCI version    = 3.00
>>>> Device ID      = 29b2h,
>>>> PCI index      = 0h
>>>> PCI Int Pin    = INT A
>>>> Interrupt line = 10
>>>> Thanks,
>>>> Pete Mackereth
>>>> General
>>> General
Hi Pete,
i915.
> Hello,
> From show_pci:
> PCI version    = 3.00
> Device ID      = 29b2h,
> PCI index      = 0h
> PCI Int Pin    = INT A
> Interrupt line = 10
> Thanks,
> Pete Mackereth
Hi Oleg,
Thanks for the quick reply.
I have now tried Pg.i810 and Pg.i915 and they both fail, Pg.i810 seems to crash the PC whilst i915 shows only a black
screen.
When running Pg.i915 the driver runs and I can attach using a phindows session as expected.
I have attached some diagnostic information, I hope it helps.
Pete
Hi Pete,
i915.
> Hello,
> From show_pci:
> PCI version    = 3.00
> Device ID      = 29b2h,
> PCI index      = 0h
> PCI Int Pin    = INT A
> Interrupt line = 10
> Thanks,
> Pete Mackereth
General
http://community.qnx.com/sf/go/post112806
Attachment: Compressed file Diags.tar 73 KB
Hi Pete,
Sorry for my mistake, I meant Pg.i830 instead of Pg.i810. Please try Pg.i830. Also try Hydra.ms / Pg.flat*. What type of
 connection (VGA, HDMI) do you use? I’ll examine your diagnostic information.
5 янв. 2015 г., в 14:27, Pete Mackereth <community-noreply@qnx.com> написал:
> Hi Oleg,
screen.
> Regards,
> Pete
> Hi Pete,
Pg.i915.
> Respectfully,
> Oleg
>> Hello,
>> From show_pci:
>> PCI version    = 3.00
>> Device ID      = 29b2h,
>> PCI index      = 0h
>> PCI Int Pin    = INT A
>> Interrupt line = 10
>> Thanks,
>> Pete Mackereth
>> General
> http://community.qnx.com/sf/go/post112815
> <Diags.tar>
Hi Oleg,
It's VGA.
Pete
Sent: 05 January 2015 14:18
Hi Pete,
> Hi Oleg,
screen.
> Regards,
> Pete
> Hi Pete,
Pg.i915.
> Respectfully,
> Oleg
>> Hello,
>> From show_pci:
>> PCI version    = 3.00
>> Device ID      = 29b2h,
>> PCI index      = 0h
>> PCI Int Pin    = INT A
>> Interrupt line = 10
>> Thanks,
>> Pete Mackereth
>> General
> <Diags.tar>
General
http://community.qnx.com/sf/go/post112817
Hi Oleg,
See attached for a list of the drivers I've tried, the only one that works is the safe mode.
Pete
Hi Pete,
> Hi Oleg,
screen.
> Regards,
> Pete
> Hi Pete,
Pg.i915.
> Respectfully,
> Oleg
>> Hello,
>> From show_pci:
>> PCI version    = 3.00
>> Device ID      = 29b2h,
>> PCI index      = 0h
>> PCI Int Pin    = INT A
>> Interrupt line = 10
>> Thanks,
>> Pete Mackereth
>> General
> <Diags.tar>
General
Attachment: Text checked.txt 645 bytes
Hi Oleg,
Did you manage to find anything?
Pete
Hi Pete,
> Hi Oleg,
screen.
> Regards,
> Pete
> Hi Pete,
Pg.i915.
> Respectfully,
> Oleg
>> Hello,
>> From show_pci:
>> PCI version    = 3.00
>> Device ID      = 29b2h,
>> PCI index      = 0h
>> PCI Int Pin    = INT A
>> Interrupt line = 10
>> Thanks,
>> Pete Mackereth
>> General
> <Diags.tar>
General
Hi Pete,
Did you try resolutions other than 1024x768? Try 640x480 and 800x600 too.
> 6 янв. 2015 г., в 20:34, Pete Mackereth <community-noreply@qnx.com> написал:
> Hi Oleg,
> Regards,
> Pete
> Hi Pete,
of connection (VGA, HDMI) do you use? I’ll examine your diagnostic information.
> Respectfully,
> Oleg
>> Hi Oleg,
 screen.
>> Regards,
>> Pete
>> Hi Pete,
Pg.i915.
>> Respectfully,
>> Oleg
>>> Hello,
>>> From show_pci:
>>> PCI version    = 3.00
>>> Device ID      = 29b2h,
>>> PCI index      = 0h
>>> PCI Int Pin    = INT A
>>> Interrupt line = 10
>>> Thanks,
>>> Pete Mackereth
>>> General
>> General
>> General
>> <Diags.tar>
Hi Oleg,
I've tried all the combinations shown in the attached file without success.
Any other ideas?
Pete
Sent: 06 January 2015 17:49
Hi Pete,
> Hi Oleg,
> Regards,
> Pete
> Hi Pete,
> Respectfully,
> Oleg
>> Hi Oleg,
 screen.
>> Regards,
>> Pete
>> Hi Pete,
Pg.i915.
>> Respectfully,
>> Oleg
>>> Hello,
>>> From show_pci:
>>> PCI version    = 3.00
>>> Device ID      = 29b2h,
>>> PCI index      = 0h
>>> PCI Int Pin    = INT A
>>> Interrupt line = 10
>>> Thanks,
>>> Pete Mackereth
>>> General
>> General
>> General
Attachment: Text checked.txt 2.01 KB
Hi Oleg,
I have still not had any success, any other suggestions?
Pete
Hi Pete,
> Hi Oleg,
> Regards,
> Pete
> Hi Pete,
> Respectfully,
> Oleg
>> Hi Oleg,
 screen.
>> Regards,
>> Pete
>> Hi Pete,
Pg.i915.
>> Respectfully,
>> Oleg
>>> Hello,
>>> From show_pci:
>>> PCI version    = 3.00
>>> Device ID      = 29b2h,
>>> PCI index      = 0h
>>> PCI Int Pin    = INT A
>>> Interrupt line = 10
>>> Thanks,
>>> Pete Mackereth
>>> General
>> General
>> General
>> <Diags.tar>
