Forum Topic - HP Laserjet P1606dn allways prints to pages:
Dear QNX community,
i test  the printer Hp Laserjet P1606dn and it allway print to pages. The first page is the page i want to print and on
the second one. There is allways:
H<username>
    Proot
        Jstdin
             C<username>
                  Lroot
                       fdfA000xxxx (printfile)
                             UdfA000xxxx (printfille)
                                                   N
I testet it wit Pp.pc,l phs_to_pcl und on our normal filter Pp.ps.  I also testet is with older version of lpsrvr, lpd,
lpr. Allways the same result.
Kindly regards
Hans
Re: HP Laserjet P1606dn allways prints to pages
Hi Hans,
Unfortunately, I do not have HP Laserjet P1606dn to reproduce and test this issue. But this page looks like page banner.
 Try to disable page banner using printer's Embedded Web Server.
05 нояб. 2014 г., в 12:03:54, Hans Lehmann <community-noreply@qnx.com> написал:
> Dear QNX community,
on the second one. There is allways:
> H<username>
>    Proot
>        Jstdin
>             C<username>
>                  Lroot
>                                                   N
, lpr. Allways the same result.
> Kindly regards
> Hans
> http://community.qnx.com/sf/go/post112273
Hi Oleg,
thank you for your answer.
This was my idea soome days ago, but I can not find anything like page banners in Embedded Web server of printer.
Everything it looks to make problems e.g duplex and so on are disabled. There is really nothing i can find
Kindly regards
Hans
Hi Hans,
Sorry for the delay with my answer. Unfortunately, we do not have P1606 and we can't reproduce this issue on available
printers. Can you try the following config to test the printer. Create /etc/printcap file:
hpps:\
:lp=9100@192.168.1.1:rm=192.168.1.1:\
:sd=/usr/spool/output/hpps:\
:lf=/usr/adm/lpd-errs:\
:mx#0:
where 'hpps' is printer's name, 192.168.1.1 is printer's IP. For usb printer launch devu-prn and change the following
line in /etc/printcap:
lp=/dev/usbpar0
Launch following commands:
# lpd -l
# lpr -Phpps /tmp/text/txt (print text file)
# lprq -Phpps (show printer's queue)
Send me output the last command.
05 нояб. 2014 г., в 18:10:09, Hans Lehmann <community-noreply@qnx.com> написал:
> Hi Oleg,
> Kindly regards
> Hans
> http://community.qnx.com/sf/go/post112277
Hello Oleg,
thank you for reply.  i will test it later. After we had the same problem with another HP Laserjet we searched in
Internet and found some posts that HP Printer generally print a seperator page if ldp is printing (do not find the link
yet). Most of the printers have an advanced setting to disable seperator pages but not all and our customer have two
printers where you can't disable this "feature".
Kindly regards
Hans
Hello Oleg,,
I tried your recommended settings but it doesent work. Here are my output from lprq -PDeskjet
Rank   Owner      Job  Files                                 Total Size
1st    root            2     print.txt                           16 bytes
connection to 10.0.0.67 is down
the printer  send a reply to ping and old settings work with banner page
know other outputs The job hangs up in the queue
Here is my printcap
# // printcap for network printing with ethernet2USB printserver
# // 15.12.04 Hue
Deskjet:\
	:lp=:9100@10.0.0.67\
	:rm=10.0.0.67:\
#	:rp=usb1:\
	:sd=/ram/tmp:\
	:mx#0:
Kindly recards
Hi Hans,
Please provide additional information to analyze the issue:
1. Both /etc/printcaps files (that works and that based on my example).
2. Output of following commands (for both case with working and with non-working configuration):
# sin arg
# lprc status
# ping <printer_IP>
# lprq -P<printer_name>
3. Command line used to start lpd.
4. Command or description how you send files to print.
02 дек. 2014 г., в 11:34:14, Hans Lehmann <community-noreply@qnx.com> написал:
> Hello Oleg,,
> Here is my printcap
> # // 15.12.04 Hue
> Deskjet:\
> 	:rm=10.0.0.67:\
> #	:rp=usb1:\
> 	:sd=/ram/tmp:\
> 	:mx#0:
> Kindly recards
> http://community.qnx.com/sf/go/post112504
