09/18/2014 3:10 PM
post111787
Hi Jeffrey,
Sorry for the delay with my answer. I tried to reproduce your issue, but no luck. I guess I need build more complex test
stand. Can you send me output of following commands from all nodes (in one tar archive)?
sin in
sin arg
sin ver
netmap
licinfo -a
netinfo -l
ifconfig -a
show_pci -v
12 сент. 2014 г., в 22:06, Jeffrey Jordan <community-noreply@qnx.com> написал:
> I have a 6-node network connected to three different networks. It looks like this:
> |----|----|----|----|----| <- LAN 1
> [1] [2] [3] [4] [5] [6]
> |----|----| |----|----| <- LAN 2/3
> LAN 1 is a local network for process control with those 6 machines on it only.
> LAN 2/3 is a management network used for diagnostics, pushing updates and MIS connection. LAN 2 and 3 are tied
together through a WAN.
> Any suggestions on how/where to run nameloc? One of the issues I'm having is that if nameloc is not running on all
machines, it is possible that TCPIP will not run, "No License" error on start up, if it is the first machine to boot.
> Any suggestions on how to set up the netmaps? If I include all of LAN 2 and 3 on all of the machines, I get "NODE n
UP" and "NODE n DOWN" and intermittent failures when nodes 1,2,3 attempt to talk to nodes 4,5,6 and vice versa.
Currently I have a netmap that is the same on nodes 1,2,3 and the same netmap on nodes 4,5,6 - both side include thier
own 3 node 2nd network.
> http://community.qnx.com/sf/go/post111704
