Forum Topic - Pg.i830 request for higher resolutions:
Dear Foundry27,
we use the Pg.i830 driver at the moment at a resolution of 1600x1200 on a board with GME965MCH chipset.
I know that the board/grapphic chip supports also the resolution 1920x1200. But in the result of crttrap this resolution
 does not show up.
Is it possible to add the resolution 1900x1200 to the Pg.i830 driver?
Best regards,
Werner
Re: Pg.i830 request for higher resolutions
Select "custom" and then drop in the resolution that you want. The driver will try it's best, however if the hardware
supports it, it should just work.
The other way is to edit your crttrap file and put in the size there.
Best regards,
Erick
