Forum Topic - QNX 4 Product Suite 2014?:
Just curious if there is a roadmap in place to release a 2014 version since there wasn't one in 2012 and 2013?
Re: QNX 4 Product Suite 2014?
Hi Robert,
   We continue to review our release strategy associated with QNX4 on a regular basis but currently do not see enough
demand to warrant a release at this time.
   We'd be interested in hearing from the community if such a release would be of help. Please respond if this is the
case.
Leo
I would be interested in this new suite!
I too would be interested as alot of work I currently do heavily involves Qnx 4.
My company will use/sell QNX v4 based software as long as we will be able to run it on newer computers (I just approved
it for running on HP Z420). Updated installable QNX v4 Suite 201x that includes newer drivers and fixes would be very
helpful! Please note that running it in virtual environment also requires some updates.
Hello!
The QNX 4 Product Suite CD 2015 EXPERIMENTAL is available for downloading from QNX RTOS v4 Latest Software Updates page:
http://community.qnx.com/sf/wiki/do/viewPage/projects.qnx4/wiki/LatestSoftwareUpdates
Keep in mind that this is EXPERIMENTAL release. You can find changes reading the QNX4 Product Suite 2015 Release Notes:
http://community.qnx.com/sf/wiki/do/viewPage/projects.qnx4/wiki/ProductSuite2015ExperimentalReleaseNotes
Feel free to post your feedback about this CD here.
21 янв. 2015 г., в 0:20:33, Zbigniew Kazmierczak <community-noreply@qnx.com> написал:
approved it for running on HP Z420). Updated installable QNX v4 Suite 201x that includes newer drivers and fixes would
be very helpful! Please note that running it in virtual environment also requires some updates.
> http://community.qnx.com/sf/go/post113012
Hi Oleg,
I've found a couple issues with the install CD.
1. The Pg.intelhd driver does not work.(dated 2013-06-20)   I've tried all the resolutions and with every resolution all
 you end up with is a black screen.  The driver released in 2012-02-21 works well.
2. When selecting the video resolution from inside the "Photon Display Configuration" window, when you apply the changes
 the following error message is shown.  "phgraf: can not run test, please check the command  /qnx4/graphics//bin/crttrap
Celestino
Hi Celestino,
Send me crt.<node_num> and output of show_pci -v from you machine.
18 июня 2015 г., в 19:20:23, celestino almeida <community-noreply@qnx.com> написал:
> Hi Oleg,
all you end up with is a black screen.  The driver released in 2012-02-21 works well.
changes the following error message is shown.  "phgraf: can not run test, please check the command  /qnx4/graphics//bin/
crttrap"
> Regards,
> Celestino
> http://community.qnx.com/sf/go/post113974
Hi Oleg,
Attached find crt.1 and showpci.txt.
The install was done on a HP Z200 workstation.
Celestino
Attachment: Text crt.1 5.32 KB Text showpci.txt 12.63 KB
Hi Celestino,
I need to find this HW to test and fix the issue. Can you try QNX 6.5 on this hardware? If so, does it work with latest
devg-intelhd.so driver from this page?
http://community.qnx.com/sf/wiki/do/viewPage/projects.bsp/wiki/ExperimentalDriversAndUtilities
19 июня 2015 г., в 17:09:59, celestino almeida <community-noreply@qnx.com> написал:
> Hi Oleg,
> Regards,
> Celestino
> http://community.qnx.com/sf/go/post113980
> <showpci.txt><crt.1>
Hi Oleg,
Sorry for taking so long.
I've tested the latest devg-intelhd.so driver on QNX6.5 and it works perfectly.
Best Regards,
Celestino
Hi Celestino,
We’ll make back-port of current QNX6 driver to QNX4. It takes some time. You can use old Pg.intelhd driver as a
workaround.
24 июня 2015 г., в 22:08:03, celestino almeida <community-noreply@qnx.com> написал:
> Hi Oleg,
> Best Regards,
> Celestino
> http://community.qnx.com/sf/go/post114021
Hi Celestino,
Please find attached Pg.intelhd driver that has been built from the latest QNX 6.5.0 source. I can’t test it without
hardware. So try it and let me know how it works on your configuration.
> Hi Oleg,
> Best Regards,
> Celestino
Attachment: Compressed file Pg.intelhd_20140519.tar 311.5 KB
Hi Oleg,
I've tested you updated Pg.intelhd driver and the result is the same.  I'm getting a black screen for every solution
listed in the crt.1 file.  Not sure if this will help but the system is not hung when photon is launched.  If enter the
correct key sequence you are able to exit photon and back to the console from where it was launched. (Cntrl + Esc, up
arrow, Enter, tab,  Enter)
Let me know if there is anything else you would like me to test.
Celestino
Hi Celestino,
Thank you for your complete testing. Unfortunately I do not have first generation Intel HD graphics controller. So I'll
fix the driver when I find the controller.
2 июля 2015 г., в 22:19:21, celestino almeida <community-noreply@qnx.com> написал:
> Hi Oleg,
> Thanks,
> Celestino
> http://community.qnx.com/sf/go/post114056
Though I mention that the lastest Net.e1000 is working with some new hardware we have to switch to, old stuff obsolete.
 Lots of grief avoided...
Thanks.
