Forum Topic - Net.rtl8169 remote booting issue:
I noticed that the Net.rtl8169 driver size jumped from 45910 bytes (11-9-2010) to 188430 bytes (5-5-2011).  The latest
version (from 5-5-2011) has the best network stability when tested on HDD booting nodes but since the size has jumped
over 140kB it can no longer be used in my PXE remote boot kernel as the kernel size goes over the ~500kB limit.  I
figured the latest version wasn't "stripped" but that isn't the case.  Did the code base and/or compiler change?  Can a
smaller latest version be built?
Re: Net.rtl8169 remote booting issue
There was a lot of code added to the rtl8169 driver to support the latest
chipsets, so that is why the driver is so much bigger. I cannot make it
any smaller, as that would require removing code that supports newer
chipsets.
On 2013-09-30 4:07 PM, "Robert DeFreitas" <community-noreply@qnx.com>
>(11-9-2010) to 188430 bytes (5-5-2011).  The latest version (from
>but since the size has jumped over 140kB it can no longer be used in my
>Did the code base and/or compiler change?  Can a smaller latest version
>be built?
>General
>http://community.qnx.com/sf/go/post105508
>general-qnx4-unsubscribe@community.qnx.com
Thanks for the quick response Hugh.
