Forum Topic - External USB Hard Drive:
QNX 4.25 installed with 2011 Release.
Installed USB Stack V2.00K (tho I had the same issues below, before this patch).
I connect a USB hard drive (one a 2TB G-Tech, SATA I believe; the other an old 20gb PATA IDE via IDE-to-USB adapter).
I've connected both a flash drive and a CF Reader to two ports, and they were seen - but I don't remember now if I was
able to access files.
Run io-usb &
Get /dev/usb
Run usb -vvv
The device (either) is recognized.
USB 0 (UHCI) v1.10, v1.01 DDK, v1.01 HCD
    Control, Interrupt, Bulk, Isoch, Low speed
Device Address             : 1
Upstream Host Controller   : 0
Upstream Device Address    : 0
Upstream Port              : 0
Upstream Port Speed        : Full
Vendor                     : 0x4971 (G-TECH)
Product                    : 0xce33 (G-DRIVE)
Device Release             : r2.05
USB Spec Release           : v2.00
Serial Number              : EB42009V
Class                      : 0x00 (Independant per interface)
Max PacketSize0            : 64
Languages                  : 0x0409 (English), 0x041a
Current Frame              : 542 (1024 bytes)
Configurations             : 1
  Configuration            : 1 (Config0)
    Attributes             : 0xc0 (Self-powered)
    Max Power              : 0 mA
    Interfaces             : 1
      Interface            : 0 / 0 (Interface0)
        Class              : 0x08 (Mass Storage)
        Subclass           : 0x06 (SCSI)
        Protocol           : 0x50
        Endpoints          : Control + 2
          Endpoint         : 0
            Attributes     : Control
            Max Packet Size: 64
          Endpoint         : 1
            Attributes     : Bulk/OUT
            Max Packet Size: 64
          Endpoint         : 1
            Attributes     : Bulk/IN
            Max Packet Size: 64
run Fsys.umass fsys
Get Path=0 - QNX USB Storage
target=0 lun=0 Direct-Access(0) - Ext Hard  Disk Rev:
Get hd0 added to /dev/.
If I run just 'Fsys.umass' after io-usb...
Get [000] SIM="" HBA="QNX USB Storage"
[00,0,0] type=00 ver-05 resp=02 flags=00 Ext Hard Disk
Nothing new is added to /dev/.
(nor to /dos/ - I checked just in case)
Run Fsys.umass -v fsys -N usb -n usb0 &
I get the /dev/usb0
But if I try to fdisk either usb0 or hd0 device (fdisk /dev/usb0 delete, add, show, info) -
I get: //1/bin/fdisk terminated (SIGFPE ) at 0007:0000xxxx
%2       xxx Floating exception    fdisk /dev/usb0 show "Floating exception"
I also tried:
Fsys.umass -l -n Direct-Access=hd
and other combinations I've found online - most don't create any new device.
Dinit won't work as Block 1 not found ("not formatted?").
Both hard drives work fine on a Windows XP station.
I deleted the NTFS partition on the 2TB drive - now has NO partition, and I get the same error.
I can insert a small 64k flash drive into the same port and run these commands - then fdisk works fine.
Any idea, please, why these external USB hard drives aren't working?
Thx
Re: External USB Hard Drive
In attach fdisk with debug information. Please try it and provide dump
file, e.g
# dumper -d /tmp &
# fdisk /dev/usb0 show
The fdisk.dmp file should appear in /tmp/ after SIGFPE.
It seems that driver provides incorrect geometry and it will be
interesting to look what fdisk receives.
Also provide sin ar, sin info, sin ir, usb -vvv output.
Try csw_ignore option:
# Fsys.umass umass csw_ignore
Pavel
> Run io-usb &
> Get /dev/usb
> Run usb -vvv
> Device Address             : 1
> Upstream Port              : 0
> Configurations             : 1
>     Max Power              : 0 mA
>     Interfaces             : 1
>         Protocol           : 0x50
>           Endpoint         : 0
>             Max Packet Size: 64
>           Endpoint         : 1
>             Max Packet Size: 64
>           Endpoint         : 1
>             Max Packet Size: 64
> run Fsys.umass fsys
> I get the /dev/usb0
> I also tried:
> Thx
Attachment: Compressed file fdisk-dbg.tar 130 KB
