Forum Topic - Pg.i830:
Pg.i830
Hi, we have pcs with Intel video chipset that need run Photon v1.14.:
Vendor ID= 8086h, INTEL CORPORATION
Device ID=2992h,
PCI index= 0h
Class Code= 030000h Display (VGA) ProgIF=0
Revision ID= 2h
Bus number= 0
                                 Device number= 2
        Function num= 0
        Status Reg= 90h
                 Command Reg= 7h
                                                   Header type= 0h Single-function
BIST= 0h
Build-in-self-test not supported
Latency Timer= 0h
Cache Line Size= 0h
                                      Base Address= MEM@fd700000h,32bit length 1048576 MEM@d0000000h,Prefetchable,64bit
length 268435456 IO@fc00h length 8 bytes
Subsystem Vendor ID = 8086h
Subsystem ID= 2992h
                              Max Lat= 0ns
Min Gnt= 0ns
PCI Int Pin= 1, INT A
Interrupt line 	= 10
Capabilities Pointer =90h
Capability ID= 5h
Capabilities= 0h - 0h
                             Capability ID= 1h
Capabilities = 22h - 0h
When we use the driver Pg.i830 in crt.node a black screen appears and we have to reboot the PC. It concluded that it is
because the driver does not initialize the video board. But running in advance:
/qnx4/graphics/drivers/Hydra.ms -S -i0x4118 -s0x0000,0x0010 -r &
/qnx4/graphics/drivers/Pg.flatdc32 -HC0x00000010 -PX -HNqnx/crt -g1024x768x32 -A0xD0000000,0x770000 -WB4096
sleep 5
ph
works perfectly (remember that Pg.i830 is in the crt.node).
Will I be able to tell if our assessment is correct and if possible correct the problem?
Thank you very much.
Sebastián Cerella
Re: Pg.i830
Hi Sebastián,
You used  crttrap clear; crttrap trap commands to generate the crt.$NODE
file?
Please note that only the first string from the
/etc/config/trap/crt.$NODE file is used when you start the Photon.
All other strings are for the phgraphx utility
So if you want to use Pg.flatdc32 driver, put the line with this driver
to the top of the crt.$NOTEfile.
As for the Pg.i830 driver, try different resolutions and color depth to
find configuration that will work.
Pavel
> Device ID=2992h,
> PCI index= 0h
> Revision ID= 2h
> Bus number= 0
                                   Device number= 2
        Function num= 0
        Status Reg=
90h
                     Command Reg= 7h
> BIST= 0h
> Latency Timer= 0h
> Cache Line Size= 0h
64bit length 268435456 IO@fc00h length 8 bytes
> Subsystem ID= 2992h
                                Max Lat= 0ns
> Min Gnt= 0ns
> Interrupt line 	= 10
> Capability ID= 5h
                               Capability ID= 1h
is because the driver does not initialize the video board. But running in advance:
> sleep 5
> ph
> Sebastián Cerella
> http://community.qnx.com/sf/go/post94559
> To cancel your subscription to this discussion,...
Re: Pg.i830
Pavel, thanks for your answer. We tried with different resolutions with the Pg.i830 without satisfactory results. So, we
 implemented this to make the video board work with the correct driver initializing, previously, with the flat32. We
don't want to use flat32 because the refresh screen is slow. We want to use Pg.i830.
Re: Pg.i830
Have you tried the latest version of the Pg.i830 driver from the
LatestSoftwareUpdates page?
http://community.qnx.com/sf/wiki/do/viewPage/projects.qnx4/wiki/LatestSoftwareUpdates
Pavel
we implemented this to make the video board work with the correct driver initializing, previously, with the flat32. We
> http://community.qnx.com/sf/go/post94562
Re: Pg.i830
Pavel, we have tried with the latest version of the Pg.i830 driver.
Sebastián.
