QNX4 and Advantech PCE-5126QG2-00A1E MB
04/02/2012 2:05 AM
post92396
I can´t install QNX4 because program crashes on EIDE autodetect. If i take autodetect off and try manually start the
driver with correct address the driver wont find anything. With same MB in QNX6 theres no problem with the harddrive.
Anyone have any ideas? :)
Re: QNX4 and Advantech PCE-5126QG2-00A1E MB
04/02/2012 2:56 AM
post92397
Is your BIOS set to AHCI or to IDE or to "compatibility mode"?
Regards, PKY
04/02/2012 4:37 AM
post92398
BIOS is in compatible mode.
04/02/2012 4:51 AM
post92399
Hi Pekka,
There is a possibility that your boards PCI BIOS implementation is not
compatible with the Intel 386 protected mode.
http://community.qnx.com/sf/wiki/do/viewPage/projects.qnx4/wiki/InstallationNotesForProc32
To check this possibility, run Fsys.atapi driver from the shell in the
installation program (you can start shell form the QNX launch menu).
If Fsys.atapi crashes by SIGSEGV then you've faced this problem.
Pavel
> http://community.qnx.com/sf/go/post92396
04/02/2012 8:39 AM
post92400
Hi
thanks for the help. Now I can boot the qnx4 but I still have problem with the IntelHD graphics card. I downloaded Pg.
intelhd driver and crttrap.list and changed deviceId in crttrap.list to match my hardware but It wont work. I attach my
show_pci txt file here if it helps you.
> Hi Pekka,
> Regards,
> Pavel
> autodetect off and try manually start the driver with correct address the
> harddrive.
> > General
04/03/2012 4:55 AM
post92412
The Pg.intelhd driver supports only controllers listed in the
crttrap.list file.
Your controller belongs to the next generation of Intel HD which is not
supported.
I think it should work with VESA driver (Pg.flat). Have you tried it?
Pavel
> Hi
>> Hi Pekka,
>> Regards,
>> Pavel
>> harddrive.
>>> General
> http://community.qnx.com/sf/go/post92400
04/04/2012 4:30 AM
post92439
Thanks for the help. Now everything works including network card.
08/31/2012 7:15 AM
post95305
I have yet another problem with this motherboard. Im trying to use two PCI-card which is exatcly same kind of cards.
This code returns that PCI_BUFFER_TOO_SMALL error only with this motherboard. Something to do with BIOS? Do you guys
have any idea or solution how to proceed??
struct _pci_route_buffer cmd;
unsigned irq;
struct _pci_irq_routing *route, *r;
int i;
memset(&cmd, 0x00, sizeof cmd);
if(_CA_PCI_Get_Routing_Options(&cmd, 0) != PCI_BUFFER_TOO_SMALL)
return(FALSE);
if(!(route = (struct _pci_irq_routing*) _nmalloc(cmd.BufferSize)))
return(FALSE);
08/31/2012 9:25 AM
post95308
What happens if you preset cmd.BufferSize to 2K?
>PCI-card which is exatcly same kind of cards. This code returns that
>with BIOS? Do you guys have any idea or solution how to proceed??
> unsigned irq;
> int i;
> return(FALSE);
> return(FALSE);
>General
>http://community.qnx.com/sf/go/post95305
>general-qnx4-unsubscribe@community.qnx.com
09/03/2012 1:26 AM
post95326
No effect on that cmd.BufferSize preset.
> > unsigned irq;
> > int i;
> > return(FALSE);
> > return(FALSE);
> >General
09/03/2012 4:23 AM
post95330
Hi Pekka,
If you use the Proc32 with -E0 option the reason can be in the Proc32
module. With -E0 option Proc32 doesn't use PCI BIOS functions, instead
it uses software implementation of most PCI BIOS functionality.
GET IRQ ROUTING INFORMATION and SET PCI IRQ requests are not implemented
in the current version and corresponding QNX functions will return an
error.
Is it critical for you to use irq routing?
Pavel
>>> unsigned irq;
>>> int i;
>>> return(FALSE);
>>> return(FALSE);
>>> General
> http://community.qnx.com/sf/go/post95326
09/03/2012 4:37 AM
post95331
Yes im using it with -E0 option. It is critical because now my code doesn´t work with this new board. And I have to
find another way to find those identical pci-cards. And this takes time and money. But if I dont have a choice...
> Hi Pekka,
> error.
> Regards,
> Pavel
> >>> unsigned irq;
> >>> int i;
> >>> return(FALSE);
> >>> return(FALSE);
> >>> General
> > General
09/03/2012 8:29 AM
post95336
Pekka,
The -E0 option was implemented as a workaround for BIOS issue which
cause crash with SIGSEGV on PCI BIOS functions calls. You can try
different BIOS versions (if they are available) to see if you can use
Proc32 without -E0 option.
For which purpose you are using route table information?
Pavel
>> Hi Pekka,
>> error.
>> Regards,
>> Pavel
>>>>> unsigned irq;
>>>>> int i;
>>>>> return(FALSE);
>>>>> return(FALSE);
>>>>> General
>>> General
> http://community.qnx.com/sf/go/post95331
09/03/2012 9:41 AM
post95340
Hi, we are using route table information for looking the right slot where our card is defined. We have to find the right
PCI-card because example we could have I/O on first card and frequency converters on second card. Is there other way to
approach slot issue?
> Pekka,
> Regards,
> Pavel
> work with this new board. And I have to find another way to find those
> choice...
> >> Hi Pekka,
> >> error.
> >> Regards,
> >> Pavel
> >>>>> unsigned irq;
> >>>>> int i;
> >>>>> return(FALSE);
> >>>>> return(FALSE);
> >>>>> General
> >>> General
09/04/2012 6:29 AM
post95346
Hi Pekka,
In general in QNX4 for identical PCI devices logical number PCI index
and _CA_PCI_Find_Device(), _CA_PCI_Find_Class() functions are used.
You can use _CA_PCI_Find_Device() with index 0 to discover first device
and with index 1 to discover second device. The first device would be a
device that is placed higher in PCI topology.
In most cases hardware pci slot is linked with PCI device number (device
in particular slot has fixed device number). For example PCI-to-PCI
Bridge Architecture Specification describe the Device Number to Slot
Number assignment rules.
Pavel
right PCI-card because example we could have I/O on first card and frequency converters on second card. Is there other
way to approach slot issue?
>> Pekka,
>> Regards,
>> Pavel
>> choice...
>>>> Hi Pekka,
>>>> error.
>>>> Regards,
>>>> Pavel
>>>>>>> unsigned irq;
>>>>>>> int i;
>>>>>>> return(FALSE);
>>>>>>> return(FALSE);
09/05/2012 4:05 AM
post95375
Thanks Pavel for simple solution. My first touch with PCI functions!
This community support is A+ grade in my opinion.
