12/07/2011 4:33 PM
post90479
I don't see any nfs updates for 4.2, but I'm wondering if there's a fix.
Anyone else run into this?
Tom Vier <tom@triadsys.com>
Senior Net/Sys Admin
Triad Systems Engineering, Inc.
12/08/2011 2:43 AM
post90481
Hi Tom,
Only QNX 4.25 with TCP/IP 5.10 is supported now. Please, check out the QNX 4
Product Suite CD 2011:
http://www.qnx.com/download/feature.html?programid=22480
> http://community.qnx.com/sf/go/post90479
12/09/2011 11:38 AM
post90511
It appears the server is already on 4.25.
(I booted that cd and tried to install, but it doesn't actually install
anything except the boot loader, even after checking all the packages.)
BUCALB-1 {/tms5/bin} sin ver
PROGRAM NAME VERSION DATE
sys/Proc32 Proc 4.25O Aug 19 2002
sys/Proc32 Slib16 4.23G Oct 04 1996
sys/Slib32 Slib32 4.24B Aug 12 1997
/bin/Fsys Fsys32 4.24Y Apr 23 2002
/bin/Fsys Floppy 4.24B Aug 19 1997
/bin/Fsys.aha8scsi scsi 4.25G Apr 15 2002
//1/bin/Dev32 Dev32 4.23G Oct 04 1996
//1/bin/Dev32.ansi Dev32.ansi 4.23H Nov 21 1996
//1/bin/Dev32.pty Dev32.pty 4.23G Oct 04 1996
//1/etc/digi/Dq.ser32 Dq.ser 2.10 Jan 12 1998
//1/bin/Fsys.eide eide 4.25G Apr 15 2002
//1/bin/Pipe Pipe 4.23A Feb 26 1996
//1/bin/Net Net 4.25E Apr 24 2002
//1/bin/Net.i82540 Net.i82540 4.25C Jan 27 2005
//1/*/usr/ucb/Socket Socket 4.25H Jul 30 1999
//1/bin/cron cron 4.23B Oct 30 1997
//1/usr/bin/lpsrvr lpsrvr 4.24A Jun 26 1997
//1/tms5/bin/tmsver TMS p(236) 5.20B Jul 06 2007
//1/*/photon/bin/Photon Photon 1.14B Dec 04 2002
//1/*/bin/phfontpfr Photon Font 1.14H Dec 06 2002
Tom Vier<tom@triadsys.com>
On 12/8/2011 2:43 AM, Oleg Bolshakov wrote:
> Hi Tom,
12/13/2011 8:03 AM
post90570
Hi Tom,
We can't reproduce this issue. How do you launch portmap, nfsd, mountd, etc.
Please, send us:
# sin ar > sin_ar.txt
How do you mount NFS share under Linux? Which command line options do you use?
> > Hi Tom,
4
> http://community.qnx.com/sf/go/post90511
12/13/2011 11:12 AM
post90580
Thanks for looking into it more. (I wasn't able to get that cd to
actually install any packages. Maybe our license #s are too old.)
The bug is rarely triggered - weeks between occurrences.
On the qnx side, /etc/config/sysinit.1 runs /etc/config/start.network.sh
+nfs, which contains:
/usr/ucb/portmap &
if test "$1" = "+nfs"
then
sleep 1
/usr/ucb/nfsd 4 &
sleep 1
/usr/ucb/mountd &
fi
/etc/exports contains /tmp/bol
On the linux side: mount -o rw,soft,nfsvers=2 node1:/tmp/bol /mnt/bol
On 12/13/2011 08:03 AM, Oleg Bolshakov wrote:
> Hi Tom,
> Please, send us:
12/14/2011 10:31 AM
post90618
Hi Tom,
You've launched NFS server in UDP mode. Also you've used "soft" option on
mount. These may potentially damage NFS data.
Is the nfsd working correctly in TCP mode? Launch the nfsd with the following
command:
# /usr/ucb/nfsd -t 0,0,4 &
> /usr/ucb/portmap &
> then
> sleep 1
> /usr/ucb/nfsd 4 &
> sleep 1
> /usr/ucb/mountd &
> fi
> > Hi Tom,
etc.
> > Please, send us:
use?
> http://community.qnx.com/sf/go/post90580
12/14/2011 1:14 PM
post90627
Neither should cause file corruption (file is written out once on qnx
side, then eventually read by linux side). I ran tcpdump to be sure that
qnx is using udp checksums and it is. It is possible the bug is only in
the udp path of the nfsd code. I'll see if we can try tcp mode in some
production sites. We're not getting any io errors, so soft vs hard mount
shouldn't matter.
703-956-1535 office
703-984-9093 cell
703-404-0308 helpdesk
On 12/14/2011 10:31 AM, Oleg Bolshakov wrote:
> Hi Tom,
> command:
