Forum Topic - Fsys.umass error qnx_segment_alloc_flags: Not enough memory:
Because the USB drivers do not support eject detection of flash drive I'm trying to start and stop the drivers
gracefully between every access to the drive.  After a few (maybe 10+) Fsys.umass returns the above error.
io-usb and Fatfsys stay running the entire time.
Each start does the following:
Fsys.umass fsys -n0=umass
sleep 1
mount -p /dev/umass0
mount -t dos /dev/umass0t6 /dos/usb
Each stop does these:
umount /dos/usb
umount /dev/umass0
slay -fQ Fsys.umass
rm /dev/umass*
After the error occurs 'usb' returns "device 1 -descriptors - Not enough memory" in output.
Re: Fsys.umass error qnx_segment_alloc_flags: Not enough memory
Hi Chad,
Thanks for your report. I've reproduced described error on my hardware.
It seems that this is Fsys.umass issue and fix in the driver is
required.  I'll inform you when a fix would be available.
As a temporary solution you can increase  number of global segments in
the system by Proc32 option -S ( for example add -S 500 500) and rebuild
the boot image.
Pavel
> sleep 1
> umount /dos/usb
> umount /dev/umass0
> slay -fQ Fsys.umass
> rm /dev/umass*
> http://community.qnx.com/sf/go/post88974
Hi Chad,
New version of the USB stack (2.00K) is available in the LatestSoftwareUpdates section:
http://community.qnx.com/sf/wiki/do/viewPage/projects.qnx4/wiki/LatestSoftwareUpdates
In version 2.00K this problem has been fixed. Please note you have to use updated io-usb and Fsys.umass modules.
Pavel
> Hi Chad,
> the boot image.
> Regards,
> Pavel
> trying to start and stop the drivers gracefully between every access to the
> > sleep 1
> > umount /dos/usb
> > umount /dev/umass0
> > slay -fQ Fsys.umass
> > rm /dev/umass*
> memory" in output.
> > General
