06/22/2011 10:46 AM
post86778
I am just testing an IPC Kontron K.I.S.S. 4U with the CPU board PCI-759.
When the USB stack (version 2.00J, 02 June 2011) is started in the QNX text mode, everything works fine.
The main parts of the start script are:
io-usb
sleep ...
Fsys.umass fsys -l -n Direct-Access=usb
sleep ...
mount -p /dev/usb0
sleep ...
Fatfsys u0=/dev/usb0t11
When I try the same thing under Photon, io-usb and Fsys.umass are started, Fsys.umass detects the USB device, but /dev/
usb0 is not mounted by Fsys.umass. So I have no access to the USB device.
io-usb seems to work; 'usb' shows the connected USB device.
I have attached a file with some output information of 'sin irq' and 'show_pci' (in text mode and in graphics mode).
Best regards
Hans-Peter Czybik
