02/01/2011 8:23 AM
post82811
Hi Andrés,
There is no QNX4 sound driver for the 8086h:266eh device, so audio
controller won't work under QNX 4.25.
As for Advantech computer, I think that it should work generally.
> I have a Advantech computer with PCI audio integrated intel chipset
> based. Can it work with QNX 4.25?
> showpci dump:
> Vendor ID = 8086h, INTEL CORPORATION
> Device ID = 266eh,
> PCI index = 0h
> Class Code = 040100h Multimedia (Audio) ProgIF=0
> Revision ID = 4h
> Bus number = 0
> Device number = 30
> Function num = 2
> Status Reg = 290h
> Command Reg = 7h
> Header type = 0h Single-function
> BIST = 0h Build-in-self-test not supported
> Latency Timer = 0h
> Cache Line Size= 0h
> Base Address = IO@d800h length 256 bytes IO@d400h length 64 bytes
> MEM@fdffe000h,32bit length 512 MEM@fdffd000h,32bit length 256
> Subsystem Vendor ID = 414ch
> Subsystem ID = 4720h
> Max Lat = 0ns
> Min Gnt = 0ns
> PCI Int Pin = 1, INT A
> Interrupt line = 9
> Capabilities Pointer = 50h
> Capability ID = 1h
> Capabilities = c9c2h - 0h
> Thank you very much in advance.
> http://community.qnx.com/sf/go/post82723
