netinfo gives ERROR : "tx of raw data failed"
01/06/2011 10:35 AM
post81347
I'm using a AT4NM10-I (ATOM D410) with 1 realtek RTL8112L network controller.
I'm using "Net.rtl8169" and "Net" very last version.
However, sometimes, the network access does not work. When this happens, I can see in the "netinfo" and "traceinfo" the
following message :
NET(tx) tx of raw data failed
Does anyone know what could be the problem?
Best regards
Michele
Re: netinfo gives ERROR : "tx of raw data failed"
01/12/2011 3:35 AM
post81970
Hi Michele,
Did you get any messages from the Net.rtl8169 driver? Please, post here
output of the netinfo.
> Hello,
> controller.
> happens, I can see in the "netinfo" and "traceinfo" the following
> message :
> Best regards
> Michele
> http://community.qnx.com/sf/go/post81347
01/12/2011 4:40 AM
post81973
Dear Oleg,
No, I don't have any messages from the Net.rtl8169. The only message coming in netinfo is :
NET(tx) tx of raw data failed.
Another information : as said before, the problem does not occure at each startup. When the startup works correctly and
that I have the IP connectivity (so no message in netinfo), then if I remove the ethernet link and I do a ping, the same
message appears too.
Many thanks
Regards
Michele
01/14/2011 6:55 AM
post82290
Hi Michele,
It seems that there is a problem with cables or something similar. Have
you tried to use several different patch-cords? Can you try cross-cable and
test how the driver works in point-to-point mode without switch?
> Dear Oleg,
> each startup. When the startup works correctly and that I have the IP
> link and I do a ping, the same message appears too.
> Many thanks
> Regards
> Michele
> http://community.qnx.com/sf/go/post81973
02/01/2011 9:17 AM
post82820
Hi Oleg,
I have tried with a cross cable, I have exactly the same behaviour!
Regards
Michele
02/04/2011 5:36 AM
post82893
Hi Michele,
How you start the Net and the Net.rtl8169 driver?
> Hi Oleg,
> Regards
> Michele
> http://community.qnx.com/sf/go/post82820
02/04/2011 5:49 AM
post82894
Dear Oleg,
Here is how I start them :
Net &
Net.rtl8169 -V10ech -d8168 -I0 -l2 &
Regards
Michele
02/04/2011 9:22 AM
post82900
Michele,
Do you really need to specify PCI IDs and index? Please, check how the
driver works with forced speed/duplex. Try to launch the driver with
different combinations of options -s, -F, e.g.:
Net.rtl8169 -s100 -F &
Is FLEET network working when TCP/IP fails?
> Dear Oleg,
> Net &
> Regards
> Michele
> http://community.qnx.com/sf/go/post82894
02/04/2011 9:53 AM
post82904
Dear Oleg,
I've tried all combinations of
Net.rtl8169 -s100 &
Net.rtl8169 -F &
with and without specifying pci ID...
I'm not familiar with FLEET. Could you tell me how I can check FLEET network is working?
Many thanks
Regards
Michele
02/09/2011 4:40 AM
post83017
Hi Michele,
Does this issue occur with all combination of options? Also note that you
have to test the driver with -s10 and -s1000 too.
FLEET is a native QNX4 network protocol. Please, read how to configure
FLEET:
http://www.qnx.com/developers/qnx4/qnx4kb/solution.html?code=10203
> Dear Oleg,
> Net.rtl8169 -s100 &
> Net.rtl8169 -F &
> network is working?
> Many thanks
> Regards
> Michele
> http://community.qnx.com/sf/go/post82904
02/09/2011 10:35 AM
post83031
Is it possible for you to send us your hardware, so that we can rectify this problem?
Thanks, Hugh.
02/09/2011 10:54 AM
post83036
Dear Hugh,
What do you mean by sending you my hardware?
Do you need the reference of motherboard and ethernet chip, or do you need
us to send you one motherboard?
As said in my first mail, I'm using a AT4NM10-I (ATOM D410) with 1 realtek
Please let me know.
Many thanks
Kind regards
Michele
----- Original Message -----
To: "general-qnx4" <post83031@community.qnx.com>
Sent: Wednesday, February 09, 2011 4:35 PM
Subject: Re: netinfo gives ERROR : "tx of raw data failed"
> this problem?
> Thanks, Hugh.
> http://community.qnx.com/sf/go/post83031
02/09/2011 4:00 PM
post83058
Yes, if you could send us one motherboard it would help, as the problem could be specific to this motherboard and PHY.
Hugh.
02/10/2011 4:50 AM
post83066
I will try to organize that. Could you give me address and contact name to
send it?
Thank you
Regards
Michele
To: "general-qnx4" <post83058@community.qnx.com>
Sent: Wednesday, February 09, 2011 10:00 PM
> Hugh.
> http://community.qnx.com/sf/go/post83058
02/10/2011 10:09 AM
post83081
That would be great. Please send it to:
Hugh Brown,
QNX Software Systems
175 Terence Matthews Crescent,
Ottawa. ON. Canada.
K2M 1W8.
