Re: Accessing SCSI Device with Product Suite 2009 running VMWare Player 3.1
11/09/2010 11:00 AM
post74054
Can't help with the SCSI config, but if all you need is to run on VMware, then here is how..
Create a new VM in workstation with an IDE drive, get it running as you need, then copy to the ESX server datastore.
Once the copy is complete, simple browse the datastore to the vmx, then right-click and select "add to inventory". Fire
it up and you're on your way. ESX will provide Intel network adapters as follows:
Vendor ID = 8086h, INTEL CORPORATION
Device ID = 100fh,
Use Net.i82540, and if more than one, specify the index number and logical network number as shown below:
Net.i82540 -I0 -l1 -v &
sleep 4
Net.i82540 -I1 -l2 -v &
sleep 4
