Forum Topic - io-usb segfault:
io-usb segfault
Our two blade vendors are end of lifing our SBC blades.  We have been
evaluating new blades to support our QNX4.25 based application.
The attached pdf is a blade that we have working on the
    sata hard drive
    charcter io using the bios usb keyboard translation
    82571 networking using the e1000 dirver
As you can see, usb is primary interface option.
Even with the 20100707 USB2 patch  I get the following
trying to start the driver
//8/bin/io-usb terminated (SIGSEGV) at 00D1:00005330
I am attaching
pdf for the SBC
the following outputs from show_pci
show_pci1.txt - show_pci
show_pci2.txt - show_pci -v
show_pci3.txt - show_pci -vvvv
the following output from lsusb when I loaded LINUX on the board
lsusb1.txt - lsusb
lsusb2.txt - lsbsb -vvvvv
any help on how the run usb would be appreciated.
any help on what graphics driver to use would be appreciated
Attachment: PDF cpc5565.pdf 218.06 KB Text lsusb1.txt 580 bytes Text lsusb2.txt 17.2 KB Text show_pci1.txt 947 bytes Text show_pci2.txt 16.55 KB Text show_pci3.txt 28.22 KB
Re: io-usb segfault
Hi Richard,
That's quite bad situation. I'm afraid that with current version of
io-usb you can't work with usb on your board. But to clarify the situation:
1. When io-usb crash occurs: when you run io-usb without any connected
usb devices or when you connect first device or when you connect some
special device?
2. Try to run io-usb with manually specified Host Controller, for
example try
    # io-usb -d uhci pindex=0 & or
    # io-usb -d uhci pindex=1 & or
    # io-usb -d ehci pindex=0 &
Report if in some cases it will not crush.
3. Please provide io-usb trace report.
To collect trace report:
Copy attached file to the /etc/config
 - Change severity level:  # tracectrl -s7
 - Run: # tracelogger -f /trace &
 - Run # io-usb
 - After io-usb crush run: # traceinfo -M0x9 -e /etc/config/traceinfo
/trace > /io-usb.trace
 - Post here io-usb.trace file
As I see you have ATI graphical controller. It should work with Hydra.ms
and Pg.flat* driver.
In first case try:
# crttrap clear
# crttrap trap
Pavel Kozlov
Richard Miller:
>     sata hard drive
> I am attaching
> pdf for the SBC
> lsusb1.txt - lsusb
> Thanks
> http://community.qnx.com/sf/go/post65699
Re: io-usb segfault
Pavel,
Thanks for you response.
1.  io-usb seg faults with no devices attached - or any combination of
devices
2.  I ran io-usb -d [ueo]chi pindex=[012] and got sic "Error Intializing
Stack"  in each case
3.  I ran this twice to make sure I got it right - see attached - it
just contains 00
4.  crttrap  hangs at the 1st Pg.rage128 in the crttrap.list
     How should I modify the crttrap.list to get it to just trap on
Hydra and Flat ??
Richard
Pavel Kozlov wrote:
> Hi Richard,
> special device?
> example try
> Report if in some
>  - Run # io-usb
> In first case try:
> # crttrap clear
> # crttrap trap
> Regards,
> Pavel Kozlov
> Richard Miller:
>>     sata hard drive
>> I am attaching
>> pdf for the SBC
>> lsusb1.txt - lsusb
>> Thanks
>> General
> http://community.qnx.com/sf/go/post66097
Attachment: Text io-usb.trace 0 bytes
Re: io-usb segfault
Hi Richard,
Please try to collect io-usb trace info again but  this time run io-usb
with increased verbosity level:
# io-usb -vvv
May be in this case you will catch something.  If not then io-usb
crashes somewhere in Host Controller initialization before sending any
debug output into the trace buffer.
io-usb in QNX4 (20100707 USB2 patch) is a port of QNX 6.4.1 USB stack.
Can you check io-usb behavior in QNX 6.4.1 or QNX 6.5 on your board?
Anyway I suppose that to work with usb on your board io-usb modification
for your hardware is required.
Pavel Kozlov
Richard Miller:
> Pavel,
> devices
> Stack"  in each case
> just contains 00
> Hydra and Flat ??
> Richard
> Pavel Kozlov wrote:
>> Hi Richard,
>> special device?
>> example try
>> Report if in some
>>  - Run # io-usb
>> In first case try:
>> # crttrap clear
>> # crttrap trap
>> Regards,
>> Pavel Kozlov
>> Richard Miller:
>>>     sata hard drive
>>> I am attaching
>>> pdf for the SBC
>>> lsusb1.txt - lsusb
Re: io-usb segfault
Hi Pavel,
I am attaching the script of the script file I used and the output.  If
I made
any mistakes let me know and I'll correct.  I saw the same result I'm
afraid.
We will be testing QNX 6.4.1 and QNX 6.5 today and tomorrow.  I will post
you with the results as soon as I have them.
Really appreciate you help !
Richard
Pavel Kozlov wrote:
> Hi Richard,
> # io-usb -vvv
> Regards,
> Pavel Kozlov
> Richard Miller:
>> Pavel,
>> devices
>> Stack"  in each case
>> just contains 00
>> Hydra and Flat ??
>> Richard
>> Pavel Kozlov wrote:
>>> Hi Richard,
>>> special device?
>>> example try
>>> Report if in
>>>  - Run # io-usb
>>> In first case try:
>>> # crttrap clear
>>> # crttrap trap
>>> Regards,
>>> Pavel Kozlov
>>> Richard Miller:
>>>>     sata hard drive
>>>> Even with the 20100707 USB2 patch  I get the...
Attachment: Text dotrace 149 bytes Text io-usb.trace2 0 bytes
Re: io-usb segfault
Hi Richard,
I would add set and sleep commands to your script to ensure that crash
occurs before traceinfo call. Script is in attach.
I'll wait your testing results with QNX 6*.
With old QNX4 io-usb patches do you see the same situation (crash)?
Pavel Kozlov
Richard Miller:
> Hi Pavel,
> I made
> afraid.
> Richard
> Pavel Kozlov wrote:
>> Hi Richard,
>> # io-usb -vvv
>> Regards,
>> Pavel Kozlov
>> Richard Miller:
>>> Pavel,
>>> devices
>>> Stack"  in each case
>>> just contains 00
>>> Hydra and Flat ??
>>> Richard
>>> Pavel Kozlov wrote:
>>>> Hi Richard,
>>>> special device?
>>>> example try
>>>> Report if
>>>>  - Run # io-usb
>>>> In first case try:
>>>> # crttrap clear
>>>> # crttrap trap
>>>> Regards,
>>>> Pavel...
Attachment: Text dotrace 185 bytes
Re: io-usb segfault
Pavel,
Please ignore my post on the VGP - I have the flat32 working fine !
Still very interested in the USB
Richard
Pavel Kozlov wrote:
> Hi Richard,
> special device?
> example try
> Report if in some
>  - Run # io-usb
> In first case try:
> # crttrap clear
> # crttrap trap
> Regards,
> Pavel Kozlov
> Richard Miller:
>>     sata hard drive
>> I am attaching
>> pdf for the SBC
>> lsusb1.txt - lsusb
>> Thanks
>> General
Re: io-usb segfault
Forgot to attach traceinfo file.
Pavel Kozlov
Attachment: Text traceinfo 14.51 KB
