Problem with the Net.e1000 and 0x10a7 device
05/13/2010 12:33 PM
post54552
I have board with 82575EB NIC:
Vendor ID = 8086h, INTEL CORPORATION
Device ID = 10a7h,
PCI index = 0h
Class Code = 020000h Network (Ethernet) ProgIF=0
Revision ID = 2h
Bus number = 1
Device number = 0
Function num = 0
Status Reg = 10h
Command Reg = 7h
Header type = 0h Multi-function
Latency Timer = 0h
Cache Line Size= 10h un-cacheable
Base Address = MEM@fdee0000h,32bit length 131072 MEM@fdec0000h,32bit length 131072 IO@dc00h length 32 bytes MEM@
fdebc000h,32bit length 16384
Expansion ROM = fde80000h length 131072 disabled
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = 1, INT A
Interrupt line = 10
Capabilities Pointer = 40h
Capability ID = 1h
Capabilities = c822h - 21002000h
Capability ID = 5h
Capabilities = 80h - 0h
Capability ID = 11h
Capabilities = 9h - 3h
Capability ID = 10h
Capabilities = 2h - 8cc1h
Device Dependent Registers:
0x40: 01 50 22 c8 00 20 00 21 00 00 00 00 00 00 00 00
0x50: 05 60 80 00 00 00 00 00 00 00 00 00 00 00 00 00
0x60: 11 a0 09 00 03 00 00 00 03 20 00 00 00 00 00 00
0x70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0x90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xA0: 10 00 02 00 c1 8c 00 00 10 28 19 00 41 6c 03 02
0xB0: 00 00 41 10 00 00 00 00 00 00 00 00 00 00 00 00
0xC0: 00 00 00 00 1f 00 00 00 00 00 00 00 00 00 00 00
0xD0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xE0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0xF0: 00 00 00 00 00 00 00 00 00 00 00 00 8e 1f 00 00
The driver is started as follows:
Net.e1000 -s100 -I0 -l1 &
Driver detects card but there is a problem with communictation
(see FIFO Overruns During Rx).
Driver Slot 0: Driver Pid 12506 Logical Net 1 Network Card: Ethernet/
INTEL PRO/1000 Gigabit (Copper) Ethernet Controller
Vendor ID ........................ 0x8086
Device ID ........................ 0x10a7
Revision ......................... 0x2
Physical Node ID ................. 0090FB 25DE94
Media Rate ....................... 100Mb/s HDX
Mtu .............................. 1514
I/O Port Range ................... 0xFDEE0000 -> 0xFDEEFFFE
Hardware Interrupt ............... 10
Total Packets Txd OK ............. 1708
Total Packets Txd Bad ............ 0
Tx Collision Errors .............. 0
Tx Collision Errors (aborted) .... 0
Carrier Sense Lost on Tx ......... 0
FIFO Underruns During Tx ......... 0
Tx deferred ...................... 0
Out of Window Collisions ......... 0
Total Packets Rxd OK ............. 262
Total Rx Errors .................. 0
Multicast Packets Received ....... 0
Broadcast Packets Received ....... 262
FIFO Overruns During Rx .......... 2285
Alignment errors ................. 0
CRC errors ....................... 0
In result a new node is not visible under QNX4 Network.
How can I solve this problem ?
Is anybody using Net.e1000 with 0x10A7 device ?
Jacek
