Forum Topic - 2009 Installation CD Install:
Hiya,
  I'm having an issue running the install CD on a supermicro 5015b_MT hardware.
  The Installation window 'disappears'  i.e. it seems to stop when autodetecting hardware.  It doesn't crash, but
doesn't seem to do anything either
  Running in diognostic mode, this occurs when I leave the PCI Bios checked.  It also stops on some of the NIC drivers.
  Please advise as to how to diagnose this problem.
-kev
Re: 2009 Installation CD Install
Hi Kevin,
1. Try to disable as much as possible in the BIOS setup (NIC, sound, RAID,
SATA enhanced mode, legacy emulated devices etc).
2. Try to unselect all checkboxes from the "Select Hardware to Auto-
detect" QNX Installer screen. Then add disk controller on the next screen.
> Hiya,
> hardware. The Installation window 'disappears'  i.e. it seems to stop
> when autodetecting hardware.  It doesn't crash, but doesn't seem to do
> anything either Running in diognostic mode, this occurs when I leave
> Thanks,
> -kev
> http://community.qnx.com/sf/go/post50929
RE: 2009 Installation CD Install
Hiya Olig,
	Thanks for helping me look into this.
	I don't suppose you know some default i/o port and IRQ values
for the HDD would be, do you?
-Kev
From: Oleg Bolshakov [mailto:community-noreply@qnx.com]
Sent: March 31, 2010 1:27 PM
To: general-qnx4
Subject: Re: 2009 Installation CD Install
Hi Kevin,
RAID,
screen.
> Hiya,
> Thanks,
> -kev
General
http://community.qnx.com/sf/go/post50990
This e-mail originates from the City of Ottawa e-mail system. Any
distribution, use or copying of this e-mail or the information it
contains by other than the intended recipient(s) is unauthorized.
If you are not the intended recipient, please notify me at the
telephone number shown above or by return e-mail and delete
this communication and any copy immediately. Thank you.
Le pr'esent courriel a 'et'e exp'edi'e par le syst`eme de courriels de
la Ville d'Ottawa. Toute distribution, utilisation ou
reproduction du courriel ou des renseignements qui s'y trouvent
par une personne autre que son destinataire pr'evu est interdite.
Si vous avez recu le message par erreur, veuillez m'en aviser par
t'el'ephone (au num'ero pr'ecit'e) ou par courriel, puis supprimer
sans d'elai la version originale de la communication ainsi que
toutes ses copies. Je vous remercie de votre collaboration.
Hi Kevin,
Please launch the driver without arguments. If it doesn't help then try to
use default i/o port 0x1F0 + IRQ 14 (for first channel) and i/o port 0x170
+ IRQ 15 (for second channel). I use next command to start Fsys.atapi on
the problematic PC (in one line):
# Fsys.atapi atapi ioport=0x1F0,irq=14,chnl=0 atapi
ioport=0x170,irq=15,chnl=1
See Fsys.atapi usage for more details.
Some ATAPI controllers don't support legacy i/o ports and IRQs, so you can
create bootable floppy with show_pci and other needed programs to
experiment with your hardware.
> Hiya Olig,
> Thanks,
> -Kev
> To: general-qnx4
> Hi Kevin,
> RAID,
> screen.
> > Hiya,
> > do anything either Running in diognostic mode, this occurs when I
> > drivers. Please advise as to how to diagnose this problem.
> > Thanks,
> > -kev
> > General
> http://community.qnx.com/sf/go/post50997
Re: RE: 2009 Installation CD Install
To no avail unfortunately.  It does not seem to see the disk (Sata1 - 320GB).  Have disabled anything I could find
related to the hard drive.
The install works fine on supermicro 5013s, but doesn't seem to like something on the 5015 (I thought I saw ICH9R on one
 of the supported harware lists)
Or do you think I am off on that?
Hi Kevin,
Send me show_pci -vvv (or similar) output from 5015.
> 320GB).  Have disabled anything I could find related to the hard
> drive. The install works fine on supermicro 5013s, but doesn't seem to
> like something on the 5015 (I thought I saw ICH9R on one of the
> supported harware lists) Or do you think I am off on that?
> http://community.qnx.com/sf/go/post51052
I cannot find the utility.  I'm assuming it is on the CD, but asides from booting to it, the install can't find the the
CD drive either (It's running on the IDE cable and the EIDE disk controller cannot find it).
When I run the shell window and go to the root, I have the dev,ram and tmp (empty) directories.  The CD I am using was
shipped to me from QNX.
I'm not quite sure what I'm doing wrong here ...
Hi Kevin,
You have to prepare bootable floppy with show_pci and other utilities. If
it's not suitable for you then contact your QNX support. In any case it
seems that we need your hardware for test and development purposes.
> from booting to it, the install can't find the the CD drive either
> find it). When I run the shell window and go to the root, I have the
> dev,ram and tmp (empty) directories.  The CD I am using was shipped to
> me from QNX. I'm not quite sure what I'm doing wrong here ...
> http://community.qnx.com/sf/go/post51214
Thanks for your assistance Oleg.
I don't suppose you know of a more modern 1u rackmount system that the QNX4 OS supports, do you?
Kevin,
I don't know... But I recommend to test hardware before buying.
> http://community.qnx.com/sf/go/post51258
