02/16/2010 7:41 AM
post47357
Hi Mak,
How do you launch the ./open_test? Please provide me a complete instructions: boot, log in, etc... Also note that there
is no controlling terminal until tinit started.
> # ./open_test /dev/tty
> Opening '/dev/monkeys'
> Failed: No such file or directory
Are you sure?
> I'm having a problem with a program that I ported to QNX. The program attempts
> to open /dev/tty, and on the eight systems I've tested (2x 4.24 and 6x 4.25),
> in works on seven and fails on one. None of these systems actually have /dev/
> tty listed in the filesystem, mind you. Additionally, the system that fails to
> open /dev/tty has the exact same version of all the modules/daemons that
> another system that can open /dev/tty, as shown below:
> # sin ver
> PROGRAM NAME VERSION DATE
> /boot/sys/Proc32 Proc 4.25O Aug 19 2002
> /boot/sys/Proc32 Slib16 4.23G Oct 04 1996
> /boot/sys/Slib32 Slib32 4.24B Aug 12 1997
> /bin/Fsys Fsys32 4.24Y Apr 23 2002
> /bin/Fsys.atapi atapi 4.25G Aug 08 2007
> //2/bin/Dev32 Dev32 4.23G Oct 04 1996
> //2/bin/Pipe Pipe 4.23A Feb 26 1996
> //2/bin/Dev32.ser Dev.ser 4.25A Feb 14 2003
> //2/bin/Dev32.ansi Dev32.ansi 4.23H Nov 21 1996
> //2/bin/Dev32.par Dev32.par 4.25A Jan 08 2001
> //2/bin/Dev32.pty Dev32.pty 4.23G Oct 04 1996
> //2/bin/Net Net 4.25E Apr 24 2002
> //2/bin/Net.befe124 Net.befe124 4.25C Nov 27 2004
> //2/*/5.0/usr/ucb/Tcpip Tcpip 5.00A Jan 26 2001
> //2/bin/cron cron 4.23B Oct 30 1997
> I've created a quick-and-dirty test for this issue, the code for which is
> attached to this post.
> On seven of my systems, I get the following results:
> # ./open_test /dev/monkeys
> # ./open_test /dev/null
> Opening '/dev/null'
> Passed.
> Opening '/dev/tty'
> Passed.
> On one of my systems, I get the following results:
> Opening '/dev/null'
> Passed.
> Any suggestions on how to correct my one machine so that opening /dev/tty is
> possible would be greatly appreciated.
