Forum Topic - Realtek RTL 8100 network driver:
Whether Net.rtl driver supports the Realtek RTL8100 network adapter? or may be Net.rtl8169?
Re: Realtek RTL 8100 network driver
Hi Arkady,
I think that Net.rtl may supports the Realtek RTL8100. Please post output
of show_pci -vvv utility (or similar info). As I know Realtek RTL8100 has
PCI IDs like Realtek 8139, so we need to know revision of your network
controller. Also you can try to launch Net.rtl on your hardware to test
how it works.
>  may be Net.rtl8169?
> http://community.qnx.com/sf/go/post42999
If I had this hardware I would check up it, certainly.
But now I can specify only that it is RTL 8100C / RTL 8110SC
Hi Arkady,
It's very important to see output of show_pci -vvv . RTL 8110SC PCI ID is
0x8167. This controller is supported by the Net.rtl8169 driver. So you
have to test this hardware with Net.rtl8169 to be sure.
> Thanks
> http://community.qnx.com/sf/go/post43068
