Forum Topic - Fsys.atapi on Panasonic Touchbook CF-30:
I'm trying to install QNX 4.25 onto a Panasonic Toughbook CF-30 with the Intel ICH9M-E/M sata chipset.  I'm using the
latest installation CD from November 2009 and it is unable to locate the hard drive.  Is there a trick to getting the
installation to see the drive?
Re: Fsys.atapi on Panasonic Touchbook CF-30
Hi Eric,
There is a trick to start the Fsys.atapi manually while you installing:
1. Set "Run installation in diagnostic mode. / F12" check box on the first
QNX Installer 2009 screen. Then press Next.
2. Unset "EIDE Disk Controller" on the "Select Hardware to Auto-detect"
screen and press Next.
3. When "Auto-detecting Hardware..." is done use "Add" button to run the
Fsys.atapi driver. In opened window choose category "Disk Controllers" and
hardware driver "EIDE Disk Controller". Enter in the Command Line:
Fsys.atapi atapi ioport=0x1f0,irq=14 atapi ioport=0x170,irq=15
And press OK.
The ioport=0x1f0,irq=14 and ioport=0x170,irq=15 are generic parameters.
You can get specific I/O ports and IRQs from the PCI configurations.
Next thread may be helpful: http://community.qnx.com/sf/go/post40388
>  the Intel ICH9M-E/M sata chipset.  I'm using the latest installation
>  there a trick to getting the installation to see the drive?
> http://community.qnx.com/sf/go/post42265
23-July-2010
I have the same problem.  Panasonic CF-30 toughbook.  I get to the hardware scan and cannot get the HDD recognised.  I
tried running Fsys.atapi manually with this command:
Fsys.atapi atapi ioport=0xe150,ira=10 atapi ioport=0xc040,irq=15
But neither the CD nor the HDD were found.
If I run Fsys.atapi with no arguments, only the CD is found.
I tried looking in the BIOS, but there are no options associated with the SATA controller.
Has anyone got a resolution to this problem?
Please email me direct: tcrees@ise.bc.ca
Thanks, Tristan.
Hi Tristan,
Sorry for delay with answer. Please post here show_pci -vvv output.
CC to tcrees@ise.bc.ca . Also you can subscribe to receive new answers in
any topic on the Foundry27.
> 23-July-2010
> hardware scan and cannot get the HDD recognised.  I tried running
> Fsys.atapi manually with this command: Fsys.atapi atapi
> Thanks, Tristan.
> http://community.qnx.com/sf/go/post60496
