Forum Topic - TimerTree: (4 Items)
TimerTree
I'm trying to use a timertree for some watchdogs.
In this particular case I have 3 producers which all three have a watchdog with a certain timeout. Each instance of the
watchdog does a Set(fire, sigc::mem_fun(*this, &Watchdog::run)). And here it goes wrong.
fire is ofcourse a PosixAPI::Timer::Reltime with different times. Set returns a timernode, but for each set it returns
the same timernode. This should be different nodes because the timestamps are different.
When I examine the timertree, it indeed has only 1 node with 3 callbacks, instead of 3 nodes, with each 1 callback.
I can't figure out where exactly it goes wrong. Maybe somebody can get me on the right track?
Re: TimerTree
Hi Bert,
Sorry for the delay.  Could you post your code? Meanwhile, I will write a test case for the timer tree and commit it (I
had one, but I seem to have lost it :-(
Re: TimerTree
Bert,
I have created a test case, and reproed the issue.  Should have a fix tonight.  Sorry about that... the TimerTree has
been neglected.
Re: TimerTree
Rennie,
Any progress on the fix for the TimerTree? At the moment I've solved it differently, but it would be nice to be able to
use it in the future.
