Forum Topic - Packet filter questions:
I am trying to config the Packet filter to redirect all the UDP packet come to the perticular IP address spcesfied port
ot another IP address another port.
For example, I want :
all the UDP packet to en0 IP address 192.168.1.1 port 60000
redirect to
IP address 192.168.3.255 port 50000
(basically change a unicast to broad cast)
what I have done is:
1. first "mount -Ttcpip lsm-pf-v4.so"
2. edit  /etc/pf.conf to:
ext_if="en0"
rdr pass on $ext_if inet proto udp from any to 192.168.1.1 port 60000 -> 169.254.3.255 port 50000
3. when I run: "pfctl -f /etc/pf.conf -vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv"
it feed back as:
No ALTQ support in kernel
ALTQ related functions disabled
Loaded 345 passive OS fingerprints
ext_if = "tsec0"
@0 rdr pass on en0 inet proto udp from any to 192.168.1.1 port = 60000 -> 169.254.3.255 port 50000
After that
I start wireshark & another software purely send out UDP packet
after I send a udp message to 192.168.1.1 port 60000, the wirehark captrue that ICMP the destination port is unreachable
am I missing anything? I think this should be straight away:(
Re: Packet filter questions
Hi Ji,
 From a high level, AFAIU, the translated UDP packets will be delivered
to the stack and processed as incoming again.
If you wanted the redirected packets to be sent out on a wire, then you
should make sure your IP forwarding flag is on. If forwarding is on,
then I'd expect the packet to be attempted to be delivered locally (i.e.
see if destination matches an address assigned to the interface) or be
forwarded. If forwarding is off, then I'd expect the packet to be
attempted locally only.
However, you're translating to a destination address under the prefix
169.254.0.0/16 which is reserved as link-local, see
http://iana.org/assignments/ipv4-address-space/ipv4-address-space.xml
Link-local packets should stay link-local, so setting up forwarding of
that isn't really ok.
A node that receives the redirected UDP packet will try to match it
against its open UDP sockets. If there are no matching sockets, then you
should expect to see the the port unreachable ICMP error that you are
seeing.
I suggest you check the UDP stats and ICMP stats to see what is
happening in the local stack. And (if forwarding was what you wanted)
that you check forwarding stats to see if there are any unroutable
packets dropped. And if you did expect a matching socket to receive the
packet, then check what opened sockets you have using netstat.
Hope this helps!
/P
i.e. in your rule:
169.254.3.255 is technically not a broadcast because it is out of a /16, so 169.254.255.255 would be its broadcast.
> i.e. in your rule:
Hi Patrik :
I have forced to configure the IP to 169.254.3.1/24, see the result of ifconfig
# ifconfig tsec1
tsec1: flags=8a43<UP,BROADCAST,RUNNING,ALLMULTI,SIMPLEX,MULTICAST>  mtu 1500
        capabilities tx=0
        enabled=0
        address: 00:20:ce:e0:00:31
        media: Ethernet none
        inet 169.254.1.15 netmask 0xffffff00 broadcast 169.254.1.255
So I guess the broadcast 169.254.1.255
as I understand(may be mistake), the broadcast address is depend on how you subneting, however, if use a old protocol,
RIPv1 for example, it will use the default netmask, but if use the later version, should be fine.
Ji Dong wrote:
>> i.e. in your rule:
> Hi Patrik :
> # ifconfig tsec1
>         capabilities tx=0
>         enabled=0
Yes, the subnetting you've used will cause 169.254.1.255 to become a
broadcast address.
Not sure whether, or even if, there should be a difference depending on
RIP version. I don't believe there should.
Back to your original question however, you may have to turn on IP
directed broadcast if you want this packet to get forwarded. See sysctl
for net.inet.ip.directed-broadcast. I believe this is turned off by
default, a DoS security issue, hence probably why you don't see it come
out the wire again after the pf translation.
Hope this helps!
/P
> Ji Dong wrote:
> >> i.e. in your rule:
> 169
> > Hi Patrik :
> ifconfig
> > # ifconfig tsec1
> >         capabilities tx=0
> >         enabled=0
> broadcast address.
> subneting, however, if use a old protocol, RIPv1 for example, it will use the
> Hope this helps!
> /P
Thanks Patrik :
You are right, I have not enable net.inet.ip.directed-broadcast, however, after I enable this option, the pf is still
not working as previously.
I have changed 169.254/16 IP address to 192.168.x/24 range, but things still not improved.
I have used "netstat -p udp"
the line:
12 dropped due to no socket
is increment by 1 every time I send the message to 60000
and I have use a software listen to port 50000, so I guess, the packet have been dropped due to no socket.
I have write a simple process just monitor 60000 port, and redirect to broad cast, as a temp solution. however, I am
still interested how to make pf works
Cheer
Ji
What about 'netstat -p ip'? And what UDP sockets are reported in plain
'netstat'?
/P
> 'netstat'?
> /P
I am use:
# netstat -p udp
udp:
        25 datagrams received
        0 with incomplete header
        0 with bad data length field
        0 with bad checksum
        0 broadcast/multicast datagrams dropped due to no socket
        0 dropped due to full socket buffers
        23 delivered
        13 PCB hash misses
        26 datagrams output
Yes, can you please send the output of 'netstat -p ip' and 'netstat'?
Maybe there are some clues there.
/P
> /P
# netstat -p ip
ip:
        739 total packets received
        0 bad header checksums
        0 with size smaller than minimum
        0 with data size < data length
        0 with length > max ip packet size
        0 with header length < data size
        0 with data length < header length
        0 with bad options
        0 with incorrect version number
        0 fragments received
        0 fragments dropped (dup or out of space)
        0 fragments dropped (out of ipqent)
        0 malformed fragments dropped
        0 fragments dropped after timeout
        0 packets reassembled ok
        694 packets for this host
        0 packets for unknown/unsupported protocol
        65 packets forwarded (0 packets fast forwarded)
        12 packets not forwardable
        33 redirects sent
        0 packets no matching gif found
        711 packets sent from this host
        50 packets sent with fabricated ip header
        0 output packets dropped due to no bufs, etc.
        8 output packets discarded due to no route
        0 output datagrams fragmented
        0 fragments created
        0 datagrams that can't be fragmented
        0 datagrams with bad address in header
Hi, do you mind sending the output of 'netstat' command?
/P
> /P
of cause:
# netstat
Active Internet connections
Proto Recv-Q Send-Q  Local Address          Foreign Address        State
tcp        0      0  192.168.3.12.8000      192.168.3.254.1439     ESTABLISHED
tcp        0      0  192.168.3.12.8000      192.168.3.254.1438     ESTABLISHED
tcp        0      0  *.phrelay              *.*                    LISTEN
tcp        0      0  *.pidinsig             *.*                    LISTEN
tcp        0      0  *.pidinenv             *.*                    LISTEN
tcp        0      0  *.pidinarg             *.*                    LISTEN
tcp        0      0  *.pidinmem             *.*                    LISTEN
tcp        0      0  *.pidin                *.*                    LISTEN
tcp        0      0  169.254.1.12.domain    *.*                    LISTEN
tcp        0      0  192.168.3.12.domain    *.*                    LISTEN
tcp        0      0  127.0.0.1.domain       *.*                    LISTEN
tcp        0      0  *.telnet               *.*                    LISTEN
tcp        0      0  *.ftp                  *.*                    LISTEN
tcp        0      0  *.sunrpc               *.*                    LISTEN
tcp        0      0  *.time                 *.*                    LISTEN
tcp        0      0  *.http                 *.*                    LISTEN
tcp        0      0  *.8000                 *.*                    LISTEN
udp        0      0  *.*                    *.*
udp        0      0  192.168.3.12.snmp      *.*
udp        0      0  *.50000                *.*
udp        0      0  *.60000                *.*
udp        0      0  *.65531                *.*
udp        0      0  169.254.1.12.domain    *.*
udp        0      0  *.tftp                 *.*
udp        0      0  192.168.3.12.domain    *.*
udp        0      0  *.1023                 *.*
udp        0      0  127.0.0.1.domain       *.*
udp        0      0  *.route                *.*
udp        0      0  *.time                 *.*
udp        0      0  *.1022                 *.*
udp        0      0  *.syslog               *.*
udp        0      0  *.*                    *.*
udp        0      0  *.sunrpc               *.*
Active UNIX domain sockets
Address  Type   Recv-Q Send-Q    Inode     Conn     Refs  Nextref Addr
48153578 stream      0      0 48157708        0        0        0 var/run/ndc
48153530 stream      0      0 481575f8        0        0        0 var/run/rpcbind.sock
I can't find pkfilter information, however, here is my ifconfig output:
tsec0: flags=8a43<UP,BROADCAST,RUNNING,ALLMULTI,SIMPLEX,MULTICAST> mtu 1500
        capabilities tx=0
        enabled=0
        address: 00:20:ce:e0:00:30
        media: Ethernet autoselect (100baseTX full-duplex)
        status: active
        inet 192.168.3.12 netmask 0xffffff00 broadcast 192.168.3.255
tsec1: flags=8a43<UP,BROADCAST,RUNNING,ALLMULTI,SIMPLEX,MULTICAST> metric 16 mtu 1500
        capabilities tx=0
        enabled=0
        inet 169.254.1.12 netmask 0xffffff00 broadcast 169.254.1.255
pflog0: flags=0 mtu 33192
I am working on a MPC8313 Target, and running the BSP modified from freescale MPC8313 BSP 6.4.0 package
You can display statistics using the pfctl utility, see:
http://www.qnx.com/developers/docs/6.4.1/neutrino/utilities/p/pfctl.html
Hi
What I have done:
1. mount -Ttcpip lsm-pf-v4.so
2. edit "/etc/pf.conf"
ext_if="tsec0"
rdr pass on $ext_if inet proto udp from any to any port 60000 -> 192.168.1.255 port 50000
Note: That is the only two line in my pf.conf
3.pfctl -f /etc/pf.conf -vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
the out put on terminal is:
ext_if = "tsec0"
@0 rdr pass on tsec0 inet proto udp from any to any port = 60000 -> 192.168.1.255 port 50000
Note: I guess the last line shows the redirect have been loaded
4. netstat
output is:
# netstat
tcp        0      0  192.168.3.12.8000      192.168.3.254.2348     ESTABLISHED
tcp        0      0  192.168.3.12.8000      192.168.3.254.2347     ESTABLISHED
udp        0      0  *.*                    *.*
udp        0      0  *.50000                *.*
udp        0      0  *.60000                *.*
udp        0      0  *.65531                *.*
udp        0      0  *.tftp                 *.*
udp        0      0  *.1023                 *.*
udp        0      0  *.route                *.*
udp        0      0  *.time                 *.*
udp        0      0  *.1022                 *.*
udp        0      0  *.*                    *.*
As you have seen last time, there is no pf filter listening on relevant port.
Have I missing anything?
I should have been clearer. Try some of the pfctl command options which
output statistics about which rules are hit. E.g. see the documentation
link above and look for example at -v and -s, . There are also examples,
e.g. -vvsTables and -vTshow.
Hope this helps!
/P
Thanks Patrik:
I have try to use pfctrl to display some informations, however, it is not really helpful. the out put always:
I have listed some of my tryings and output:
# pfctl -vvsTables
# pfctl -vvsstate
# pfctl -vvTshow
usage: pfctl [-AdeghmNnOoqRrvz] [-a anchor] [-D macro=value] [-F modifier]
             [-f file] [-i interface] [-k host] [-p device] [-s modifier]
             [-t table -T command [address ...]] [-x level]
It seems every command I used from the help file it will output:
I have no idea what ALTQ is, and what is ALTQ related functions.
The version of pfctrl is:
NAME=pfctl
DESCRIPTION=Control the packet filter and network address translation device
DATE=2008/10/20-23:17:01-EDT
STATE=Stable
HOST=trunkbuild
USER=builder
VERSION=6.4.0
the version of lib is:
NAME=lsm-pf-v4.so
DESCRIPTION=Packet Filter loadable stack module.
DATE=2008/10/20-22:48:38-EDT
STATE=Stable
HOST=trunkbuild
USER=builder
VERSION=6.4.0
> Hope this helps!
> /P
You can safely ignore the messages about ALTQ, since for what you're
doing you don't need and are not trying to use it.
/P
> # pfctl -vvsstate
There doesn't seem to be any state created by translations.  It is as if
pf isn't enabled or doesn't match the packets you send...
What does 'pfctl -vvs all' say before and directly after sending
packets? (note: the state times out) Is there any rules evaluated?
A shot in the dark, did you do 'pfctl -e' to enable the rules???
Other things to try:
Perhaps try is to tcpdump on the pflog0 interface to see what packets
are hitting the pf:
http://netbsd.gw.com/cgi-bin/man-cgi?pflog+4+NetBSD-4.0
Try slaying inetd, portmap, dhcp.client and any other process that's
using UDP sockets (see pidin fds as root).
Could try adding '-x loud' when you're loading the filter rules file.
Not sure where the "loud" debug goes though...
/P
Hi Patrik:
I have not use "pfctl -e" to enable the rules, now pf work correctly as I expected, Thanks a lot for your help.
RE: Packet filter questions
> From: Ji Dong [mailto:community-noreply@qnx.com]
> Sent: September 30, 2009 3:38 AM
> To: technology-networking
> Subject: Re: Packet filter questions
[snip]
relevant
> port.
Packet filter works by exam ALL the packets going through him, if a
packet match one of the pattern/rule, it take certain action.
It does not open any socket, nor will it "listen on a port".
-xtang
> Hi Ji,
> seeing.
> Hope this helps!
> /P
Hi Patrik:
Thanks for your quick respones.
Our network will be for local use only, it will never expose to internet, and our device have 2 Ethernet port, so my
plan is:
1.Use 192.168.xxx.xxx/24 as our routeable network.
2. Use 169.254.0.0/16  as local net
I understand for link-local address, as per iana, there are a lot of limitation for that, for example, it is not
routeable, however, I find it seems not comply to QNX implmentation.
I have do a small test, I enable RIP2 for both port, and I can see the interesting thing is the routing table is
updating on the other side, and I can send a package form one port and route though the other port to go to another
device.
Then I guess these sort of address is depend on configuration of routed for example. without these special configuration
, the TCP/IP stack will treated as no more than a normal IP addresses.
For this feature, I possiblely can rely on some comercial router to stop our local net spread out our device group.(not
sure if this is a correct way to do it, however, it looks work in our project)
Because I have enable RIP2, and it can route, so I am quite sure, the ipforward is enabled
BTW: can you suggest how can I check  forwarding stats? I have use pfctrl in a vebose mode, but there is no such
forwarding stats come on my screen.
Is it your goal to make the link-local address (169.254) to talk to
192.168?
The "autoip" module (lsm-autoip.so) is designed to auto assign
link-local and make sure a link-local address would be able to talk to a
local LAN address. (As per Link-Local required)
Just thought I should mention this.
-xtang
> Sent: September 18, 2009 3:56 AM
> > Hi Ji,
delivered
you
(i.e.
be
prefix
of
you
are
> > seeing.
wanted)
the
> > Hope this helps!
> > /P
> Hi Patrik:
internet,
> and our device have 2 Ethernet port, so my plan is:
> limitation for that, for example, it is not routeable, however, I find
it
> interesting thing is the routing table is updating on the other side,
and
go
> to another device.
routed
> for example. without these special configuration, the TCP/IP stack
will
stop
> our local net spread out our device group.(not sure if this is a
correct
pfctrl
> in a vebose mode, but there is no such forwarding stats come on my
screen.
> Technology
> http://community.qnx.com/sf/go/post38246
Re: RE: Packet filter questions
Hi Xiaodan :
I am useing Freescale MPC8313 BSP v6.4.0, and I have not include lsm-autoip.so lib. and all ip address is fixed assigned
I have tried to change (169.254) to 192.168.1.255, and it is still not working, exact the same as I have seen for (169.
254) :(
Ji
> Hello,
> 192.168?
> -xtang
It is not about whether you expose it to the Internet or not. (it'll
just get dropped anyways).
Link-local does not mean "local to your site". It means it is intended
to stay on the link - i.e. not leave the ethernet segment. Just like
IPv6 link-local addresses work (fe80::/10).
device.
There's nothing wrong with the QNX implementation. If you configure
io-pkt to route 169.254.0.0/16 somewhere, then it will obey that
configuration. Unlike IPv6 link-local addresses, IPv4 link-locals did
not exist in the original specs and were added later so there is no
requirement on stacks to treat them specially.
I'm saying what you're doing is a misconfiguration unless you have some
very specific (and peculiar) requirements :-) I can't comment on it
further without knowing your particular requirements but it sounds like
you should be using private addressing.
configuration, the TCP/IP stack will treated as no more than a normal IP addresses.
Yes, that's the design intent.
(not sure if this is a correct way to do it, however, it looks work in our project)
Please see the documentation for the netstat command (e.g. netstat -p
ip) here:
http://www.qnx.com/developers/docs/6.4.1/neutrino/utilities/n/netstat.html
/P
