Forum Topic - Jumbo Packet: (2 Items)
Jumbo Packet
We have seen a nice reduction in CPU usage and  utilitizing jumbo packet.
The documentation mentions it can be improved further by using "-ptcpip pagesize=8192,mclbytes=8192". My question is how
 will this affect memory usage and performance if jumbo packet are not used.
I guess if the jumbo packet size is set at 9000 pagesize should be 12288 which means it's not as efficient memory wise?
RE: Jumbo Packet
Yeah, jumbo packets are great!  Too bad there
isn't an IEEE standard for them  :-(
With enough CPU, you're probably doing gige wire
rate anyways (assuming you're using PCI-X).
The effect of the above is to defragment the received
jumbo packets, so that they fit into one buffer (and
consume one rx descriptor) instead of consuming four
rx descriptors.  This will reduce your CPU usage and
PCI-X bus usage.
Off the top of my head, going from 2k to 8k MCLBYTES
is going to require four times as much memory for rx.
right - you have to decide if exceeding 8K is
really worth it for your configuration.  You
have to look at "pidin mem" for iopkt to see
what memory it's going to cost you, and we had
a version of ttcp around here somewhere that would
display idle cpu percentage during data tranfer
benchmarking.
All of this is about reducing the cpu consumption
of io-pkt during heavy data transfer, by spending
memory.  It's the old size-vs-speed thing again.
aboyd
