Forum Topic - ping6 of link-local address failure under dual-ip configuration: (4 Items)
I have a test failing on my io-pkt stack.  This test can be explained
with 2 scenarios:
Scenario 1: io-pkt stack configured with one IPv4 address and one IPv6
address.
Scenario 2: io-pkt stack configured with one IPv6 address
In scenario 1, ping6 fails on the link-local address assigned to the
stack.  However, ping6 on the link-local address assigned to the stack
succeeds in scenario 2.
I have attached 2 files with the details of the scripts I use for both
the scenarios. Note the following points about the scenarios:
*	A private VLAN (192.168.1.1) exists in both scenarios - it is
not included in the configuration scripts since I don't "think" it plays
an issue.
*	ping works for all IPv4 network address in scenario1 (e.g. this
is specifically a ping6 problem with the IPv6 link-local address)
*	ping6 works for the IPv6 address I assigned in scenario1 (e.g.
this is specifically a ping6 problem with the IPv6 link-local address)
Questions:
1.	Is my configuration script for the dual IP scenario correct?  If
not, what adjustments need to be made?
2.	If the configuration script is correct, does scenario 1 work for
anyone else?
3.	If the configuration script is correct, does scenario 1 work for
QNX 6.3.2 using IO-NET?  Does it work for QNX 6.4.1 using IO-PKT?
Cheers,
maurice
Maurice Gibbs
Software Designer
CommTest WaveReady BU
JDS Uniphase Corp.
613.843.2326
Attachment: Text scenario1_info.txt 3.19 KB Text scenario2_info.txt 3.28 KB
Re: ping6 of link-local address failure under dual-ip configuration
Hi again,
Which version of QNX are you using? I'm using 6.4.1.
I can't ping6 a link-local address without specifying the interface
using -I option. This is really expected since link-local addresses have
link-local scope and as such only have a meaning when presented in
conjunction with a link (interface) to specify its scope. If I don't
specify the interface I get the error:
ping6: UDP connect: No route to host
Did you see that error message? Can you try specify the -I option to ping6?
Do you see any difference in statistics between the two scenarios? (see
e.g. netstat -p ip6/icmp6)
I note in scenario1_info.txt that the routing table seems cut off, is
there any more relevant info there?
Cheers!
/P
maurice gibbs wrote:
> with 2 scenarios:
> address.
> an issue.
> Questions:
> anyone else?
> Cheers,
> maurice
> Maurice Gibbs
> Software Designer
> JDS Uniphase Corp.
> 613.843.2326
> Technology
> http://community.qnx.com/sf/go/post36879
The difference appears to be the route flush.  You'll
need to re-add the link local route(s).  Something
like:
# route add -inet6 fe80::1%lo0 -iface fe80::1%lo0 -llinfo
On Fri, Aug 28, 2009 at 11:36:56AM -0400, maurice gibbs wrote:
> with 2 scenarios:
> address.
> an issue.
> Questions:
> anyone else?
> Cheers,
> maurice
> Maurice Gibbs
> Software Designer
> JDS Uniphase Corp.
> 613.843.2326
> Technology
Content-Description: Sourceforge Attachment
> Configuration Script
> io-pkt-v6-hc -dppc405 mac=00019c000477,deviceindex=0,pmme
> waitfor /dev/io-net/en0
> ifconfig en0 inet6 2200::a0d:9903 prefixlen 64
> route -q add -inet6 default 2200::a0d:9901
> Run-time Check on Config
> # ifconfig
> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 33192
>         inet 127.0.0.1 netmask 0xff000000
>         inet6 ::1 prefixlen 128
>         inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
> en0: flags=80008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,SHIM> mtu 1500
>         address: 00:01:9c:00:04:77
>         inet 192.168.1.1 netmask 0xffff0000 broadcast 192.168.255.255
>         inet6 fe80::201:9cff:fe00:477%en0 prefixlen 64 scopeid 0x2
> Process 368692 (ifconfig) exited status=0.
> # route show
> Routing tables
> Internet:
> Destination        Gateway            Flags
> 127.0.0.1          127.0.0.1          UH
> 192.168.0.0/16     link#2             U
> Internet6:
> ::                 2200::a0d:9901     UG
> ::1                ::1                UH
> 2200::             link#2             U
> 2200::a0d:9901     00:24:c4:eb:10:35  UHL
> 2200::a0d:9903     00:01:9c:00:04:77  UHL
> fe80::%lo0         fe80::1%lo0       ...
I am using QNX 6.3.2 with io-pkt.
Thanks Patrik and Sean.  The issue was the route flush. I've altered my scripts and ping6 now works.
Cheers,
maurice
