Forum Topic - bug: hostname: (7 Items)
bug: hostname
Hello
Hostname must be FQDN.
If I set hostname in FQDN, some subsystems (qnet) are not working
RE: hostname
re: hostname
qnet uses (and changes) _CS_HOSTNAME and _CS_DOMAIN - see confstr()
If _CS_DOMAIN is not set, qnet will set it to be "net.intra"
and if _CS_HOSTNAME is not set, qnet will manufacture a
unique ASCII string based upon the 24 bits of the ethernet
mac address which might look like "EA632C16".
aboyd
Re: RE: hostname
> re: hostname
> aboyd
if _CS_DOMAIN set example.org and _CS_HOSTNAME set qnx.example.org (FQDN), qnet uses qnx.example.org.example.org
RE: RE: hostname
Right - looking at the qnet source, I'm
pretty sure that you're going to have to
setconf _CS_HOSTNAME with the hostname, and
setconf _CS_DOMAIN with the domain.
If you're being passed a FQDN then I think
you are going to have to parse it into the
separate pieces.  I might suggest using
the strchr() library function call like this:
void parse_fqdn(char *fqdn)
    char *hostname, *domain;
    domain = strchr(fqdn,".");
    domain[0] = 0;  // overwrite dot after hostname
    domain++;
    hostname=fqdn;
    confstr(_CS_SET | _CS_HOSTNAME, hostname);
    confstr(_CS_SET | _CS_DOMAIN, domain);
a strdup of the fqdn would be a nice touch.
Typing this in, I feel a touch of nostalgia -
this is like an interview question, fresh
out of school  :-)
P.S.  (threadjack warning) I have a MUCH better
interview question!
aboyd
Re: RE: RE: hostname
No, no, no.
_CS_HOSTNAME should be fqdn!
$ getconf _CS_HOSTNAME
qnx.example.org
$ getconf _CS_DOMAIN
example.org
$ uname -a
QNX qnx.example.org 6.4.1 2009/05/20-17:35:56EDT x86pc x86
$ hostname
qnx.example.org
$ hostname -s
qnx
$ sloginfo | grep example.org
Aug 06 13:09:06    7    15     0 qnet(QOS): nd_change_notify(): Node Up:   nd 0 qnx.example.org.example.org
Aug 06 13:09:06    7    15     0 qnet(L4): lr_verify_my_name_and_domain(): starting resolution of our hostname qnx.
example.org.example.org to ensure unique
where the error occurred?
From some quick web searches, it appears that the behaviour of hostname is system specific with regards to FQDN.  See,
for example, this posting
http://www.unixguide.net/network/socketfaq/2.24.shtml
   R.
RE: RE: RE: hostname
Thx Rob.  I am reluctanct to create a PR for this
because I am still unsure that our current behaviour
is incorrect.
aboyd
