Forum Topic - Question about sending fds to other processes: (7 Items)
We have an application where we use sendmsg() & recvmsg() to pass fds across processes, and it works generally well.
However, we recently encounted an error condition where it appears as if the sender closed the handle just before the
receiver duplicated it.
Searching through source, it appears that sendmsg() uses ConnectServerInfo() to pass the information about its open fd,
and that recvmsg() receives the information, attaches to the sender's resource and sends a "dup" command to create a
copy of the handle.  But this doesn't explain how the sender knows that the receiver has finished dup'ing the handles
before it closes them.
In addition, in core_networking/trunk/sys/kern/uipc_usrreq.c, I find the following comment:
         * Idealy, we should also "dup" the fd to ours here, so even if the
         * sender close the fd after send them out, we still have a proper
         * fd and won't confuse receiver...
but then no code to actually implement the "ideal" case!  And then on the receive side:
         * Do nothing under QNX6. All the io_dup_t is passed
         * back to receiver, and receiver will dup it as they want.
         * Note if we did a "dup" in unp_internalize (to prevent sender
         * close fds), we need to close the duped fds after receiver
         * has completed its dup work.
So, I have two questions:
1. Am I reading this correctly, i.e., that there truly is a race condition where sendmsg() just sends the fd information
 and returns, and recvmsg() dups the file handles it received?  In other other words, that there is nothing stopping the
 sender from closing the file handle that it just sent before the receiver has a chance to duplicate the handle it just
received?
2. If #1 is true, what can be done, short of creating a bunch of synchronization logic to close the loop externally?
(which would really seem to be covering a bug in the stack.)
Hopefully, I'm reading the code incorrectly and missing some other mechanism that closes this hole.
lew
Re: Question about sending fds to other processes
On Mon, Jul 20, 2009 at 10:22:36PM -0400, Lewis Donzis wrote:
> We have an application where we use sendmsg() & recvmsg() to pass fds across processes, and it works generally well.  However, we recently encounted an error condition where it appears as if the sender closed the handle just before the receiver duplicated it.
, and that recvmsg() receives the information, attaches to the sender's resource and sends a "dup" command to create a
information and returns, and recvmsg() dups the file handles it received?  In other other words, that there is nothing
stopping the sender from closing the file handle that it just sent before the receiver has a chance to duplicate the
handle it just received?
Your analysis is correct.  It's not just a
synchronization issue, the other end also
needs perms to do the dup.  For example, grep
for QNXNTO in the fdpassing code in our port
of openssh:
http://community.qnx.com/integration/viewvc/viewvc.cgi/trunk/crypto/external/bsd/openssh/dist/monitor.c?root=
core_networking&system=exsy1001&view=log
http://community.qnx.com/integration/viewvc/viewvc.cgi/trunk/crypto/external/bsd/openssh/dist/monitor_wrap.c?root=
Thanks, Sean.
You know, I ported openssh over two years ago (and have done it several times since then with new releases), and this
issue never came up.  Now I'm worried that it's broken -- tempting to just use your port instead!  (Although we had to
add the ability to specify the password from the command line so that it can work like a typical router.  It's pretty
simple and I could send you the diffs if you're interested.)
We run everything as root on our target, so the permissions issue doesn't happen in our environment.  We do chroot(),
but we're just passing the fd of an open socket, so not a problem.
We were wondering whether this behavior is unique to QNX or if other implementations of sendmsg()/recvmsg() have a
similar issue?
lew
On Tue, Jul 21, 2009 at 09:52:24AM -0400, Lewis Donzis wrote:
> Thanks, Sean.
It depends on how you did the port.  If you take the stock
distribution (build from pkgsrc for example), qnx is marked as
having broken fd passing and some other method is used; however
as you've seen, it's not totally broken, just finicky.
similar issue?
This peculiarity is unique to QNX; all part of not
being a monolithic system...
BTW ssh and friends are shipped with 6.4.1.
Yeah, I see what you mean.  It looks like it basically just disables priveledge separation, which is probably find for
us since everything in the system is running as root anyway.
Were you planning on putting your changes back into the openssh project?
Yep... :)  It easy to wonder if the synchronization could be built into the library, though, so that it works
transparently.  But I presume if it was so easy, it would have already been done.
We'd be happy to use the shipped code, except that we require passwords on the command line.  (we use user:password@host
 instead of just user@host).  The changes for doing this were relatively trivial (a few lines changed in three source
files).  However, it looks like they go to all sorts of trouble to prevent this in openssh, so I figured it was some
sort of security thing.  Nonetheless, many network infrastructure systems take scp URLs with passwords on the command
line and we're obligated to copy them in our system.
lew
encounted an
>  to pass the information about its open fd, and that recvmsg() receives the
> create a copy of the handle.  But this doesn't explain how the sender knows
> that the receiver has finished dup'ing the handles before it closes them.
> following comment:
> receive side:
> where sendmsg() just sends the fd information and returns, and recvmsg() dups
> receiver has a chance to duplicate the handle it just received?
> synchronization logic to close the loop externally?  (which would really seem
> of openssh:
> bsd/openssh/dist/monitor.c?root=core_networking&system=exsy1001&view=log
external/
> bsd/openssh/dist/monitor_wrap.c?root=core_networking&system=exsy1001&view=log
> Regards,
> -seanb
While I can understand the value of adding this functionality, I can't totally understand the point of implementing it
as an unreliable delivery system such that every application ported needs to be edited to be closed loop (as you have
done in the openssh code)  Permissions aside, at least making sure that the sender can close the fd after calling
sendmsg() seems like a necessity.  Since it is entirely library code that implements the fd sending, why not code the
library such that sendmsg() does not complete until the receiving end has accepted the fd or gotten an error?
Henry
> Henry
I made a PR on it.
