Re: RE: MsgSendPulse blocking
06/15/2009 2:08 PM
post31778
> Whoops. Not sure this has anything to do with
> your problem, but it looks like I fixed that stats/delay
> ONLY in the io-net driver, NOT in the io-pkt driver,
> which clearly was branched off before then.
> If you're running 6.4 or 6.4.1, try specifying the
> io-net speedo driver instead of the io-pkt version -
> does that make any difference?
Over the week-end we try 6.4.1, out of desparation because we aren't 100% ready to deploy 6.4.1 in the field yet. It was
worse, ifconfig would block forever (at least 30sec) when trying to configure the IP address. This was with io-pkt
version.
