Forum Topic - Echo client program:
Echo client program
I've written a small program serving as a echo client. The host is on windows XP using momentics version 4.5 as
development env. The target is running on a QEMU emulator (x86).
The client program is connectiing to a echo server running on the host and is working as expected. It can perfectly
recover when I terminate and restart the echo server. However this is only the case when starting from within the
development environment. When I start up the client on the QEMU emulator the client program exits without any message
when the echo server disconnects. No message, no signal, nothing.....
I'm getting deperate since there is no way to debug this behaviour
I've attached the example I'm using for testing.
Hope someone can help
regards Wim
Attachment: Text example.cpp 2.44 KB
Re: Echo client program
> regards Wim
Are you sure you aren't getting hit with a SIGPIPE?
Try setting signal(SIGPIPE, SIG_IGN);
Sean,
signal(SIGPIPE, SIG_IGN) solved the problem. thank you!
regards Wim
> > regards Wim
And check the return value from send().
