Forum Topic - pid/nid from name: (16 Items)
pid/nid from name
I'm trying to find the pid/nid of a process from its name registered with name_attach().  It's the nid I'm having
trouble with.
Re: pid/nid from name
Can you call ConnectServerInfo on the coid?
trouble with.
> Technology
> http://community.qnx.com/sf/go/post26136
cburgess@qnx.com
RE: pid/nid from name
Hum not sure, the idea is it's possible the process is stuck in a loop, it's my understanding that a name_open() will
not work, since it wouldn't be able to handle the IO_CONNECT  message.  My goal is to kill (SIGKILL) processes that
haven't respond to our normal termination method, I cannot assume they are in a sane state.
> From: Colin Burgess [mailto:community-noreply@qnx.com]
> Sent: April-06-09 4:23 PM
> To: technology-networking
> Subject: Re: pid/nid from name
> with name_attach().  It's the nid I'm having trouble with.
> > Technology
> cburgess@qnx.com
> Technology
> http://community.qnx.com/sf/go/post26138
Try the back door then :)
/proc/mount/dev/name/[global|local]/<your_registered_name>/<node>,<pid>,
<chid>,<ftype>,<handle>
-xtang
> From: Mario Charest [mailto:community-noreply@qnx.com]
> Sent: April 6, 2009 4:35 PM
> Subject: RE: pid/nid from name
loop,
> it's my understanding that a name_open() will not work, since it
wouldn't
(SIGKILL)
> processes that haven't respond to our normal termination method, I
cannot
registered
> > > Technology
> > cburgess@qnx.com
> > Technology
> Technology
> http://community.qnx.com/sf/go/post26142
> From: Xiaodan Tang [mailto:community-noreply@qnx.com]
> Sent: April-06-09 4:39 PM
There doesn't seem to be anything under /proc/mount/dev/name/global but the info on gns
I tried it  under /dev/name/global, but the <node> field can be 0 in some cases depending on the relationship between
the location of the program and the location of the gns server, at least that is what I observed.
> -xtang
> loop,
> wouldn't
> (SIGKILL)
> cannot
> registered
> > > > Technology
> > > cburgess@qnx.com
> > > Technology
> > Technology
> Technology
> http://community.qnx.com/sf/go/post26144
There is GNS! :)
The nid always valid to whoever is looking at it.
If on node A, you have a name. AND, from same node, you do "ls", you
should see nid = 0; but if you goes to node B, and do "ls
/net/nodeA/dev/name/...", you see a nid which won't be 0 (nodeA'd nid on
B).
Not sure this is clear enough. :)
Anyway, which ever machine you are on, you should always be able to
ConnectAttach(nid, pid, chid, ..) that returns back to you.
-xtang
> Sent: April 6, 2009 4:47 PM
but
> the info on gns
some
> cases depending on the relationship between the location of the
program
> > -xtang
> > loop,
> > wouldn't
> > (SIGKILL)
> > cannot
> > registered
> > > > > Technology
> > > > cburgess@qnx.com
> > > > Technology
> > > Technology
> > Technology
> Technology
> Sent: April-06-09 4:53 PM
> There is GNS! :)
> on
> B).
Yes but this not what I'm seing.
Node A (called neutrino) runs gns -s, node B runs gns -c.  I start the application on node A and it creates "/dev/name/
global/mcharest/logc/Trace_0"
ls -l gives me "lr-xr-xr-x  0 root      root              0 Apr 07 09:01 0,172687673,2,0,12 -> ../../../net/neutrino.
comact.com/ /mcharest/logc/Trace_0/0,172687673,2,0,12"
Node is 0 hence everything look ok .  Then I go on Node B.
ls -l /dev/name/global/mcharest/logc/Trace_0 returns:
lr-xr-xr-x  0 root      root              0 Apr 07 13:01 0,172687673,2,0,12 -> ./../../net/neutrino.comact.com/mcharest/
See, the node number is still 0.  If I do like in your example, from node B I do ls -l /net/neutrino/dev/name/global/
mcharest/logc/Trace_0 I still get a 0.  Even if that method would work it's the chicken & egg problem.
> -xtang
> but
> > the info on gns
> some
> program
> > > -xtang
> > > loop,
> > > wouldn't
> > > (SIGKILL)
> I
> > > cannot
Re: RE: pid/nid from name
Does no answer means  it's can't be done?
> > There is GNS! :)
> > on
> > B).
> application on node A and it creates "/dev/name/global/mcharest/logc/Trace_0"
> 172687673,2,0,12 -> ../../../net/neutrino.comact.com/ /mcharest/logc/Trace_0/0
> ,172687673,2,0,12"
>  ./../../net/neutrino.comact.com/mcharest/logc/Trace_0/0,172687673,2,0,12
> do ls -l /net/neutrino/dev/name/global/mcharest/logc/Trace_0 I still get a 0.
> > -xtang
> > but
> > > the info on gns
> > some
> > program
> > > > -xtang
> > > > loop,
> > > > wouldn't
> > > > (SIGKILL)
RE: RE: pid/nid from name
Sorry, no answer means "it's not suppose to be that way"...
> Sent: April 8, 2009 1:21 PM
> Subject: Re: RE: pid/nid from name
> > > There is GNS! :)
you
nid
> > > on
> > > B).
the
09:01
> 0,
> > ,172687673,2,0,12"
> 2
> node B I
get
> a 0.
to
> > > -xtang
> > > but
> > > > the info on gns
0 in
> > > some
> > > program
observed.
> > > > > -xtang
Re: RE: RE: pid/nid from name
Sorry, should look at the source first. :( Maybe "it is suppose to be this way". If a filename changed because it is
viewed from different machine, things getting crazy when gns server try to sync (or it seems like...)
Anyway, the nd is "the nd of the registrer machine in gns server's view". In your case, if you register from node B
(your gns client), you should see a non-zero nd.
So if you run your program on the same node of gns server (node A), things are simple. Otherwise, you have to parse the
linked name and netmgr_strtond() it.
It doesn't sound very straight forward I guess. Connect to the server and ConnectServerInfo() is still the "official way
" to go.
RE: RE: RE: pid/nid from name
> Sent: April-08-09 5:17 PM
> Subject: Re: RE: RE: pid/nid from name
> this way". If a filename changed because it is viewed from different
> like...)
> view". In your case, if you register from node B (your gns client), you
> things are simple. Otherwise, you have to parse the linked name and
Ok thanks.
> and ConnectServerInfo() is still the "official way" to go.
Maybe it's official but it sucks since you can't connect to an unresponsive server.
> Technology
> http://community.qnx.com/sf/go/post26461
The server may not be responding to an _IO_OPEN message, but you should still be able to ConnectAttach to it... maybe
some hacky use of _connect* might get you what you want...
Colin
Sent: Wed 4/8/2009 5:18 PM
Subject: RE: RE: RE: pid/nid from name
> like...)
Ok thanks.
> Technology
Technology
http://community.qnx.com/sf/go/post26462
Attachment: Text winmail.dat 4.46 KB
> Sent: April-08-09 6:31 PM
> still be able to ConnectAttach to it... maybe some hacky use of
Either I'm brain dead or I haven't made myself clear.  I'm trying to find the nid and pid of a process via the name it
register with name_attach() so i can SigKill it.  Can't use ConnectAttach since it needs the nd, pid and chid.
Not sure what the _IO_OPEN you mentioned has to do with anything. It's the _IO_CONNECT I'm worried about. I'm assuming
_IO_CONNECT is sent by _connect_ctrl()?
> Colin
> seems
> > like...)
> Ok thanks.
> > Technology
> Technology
> Technology
> http://community.qnx.com/sf/go/post26467
(an open is actually just an IO_CONNECT with subtype IO_CONNECT_OPEN)
but you don't need a message - the connect machinery retries the nd and chid from procnto, then does a connect
attach, THEN sends an IO_CONNECT.
So if you can get as far as the ConnectAttach you're golden.
That said, the code probably doesn't directly ALLOW for this right now... but it should be possible! :-)
>> Colin
>> seems
>>> like...)
>> Ok thanks.
>>> Technology
>> Technology
>> Technology
> Technology
> http://community.qnx.com/sf/go/post26470
cburgess@qnx.com
But we need to see the return value of _IO_CONNECT message to determine
if we are talking to the right manager...
-xtang
> Sent: April 8, 2009 9:00 PM
and
now...
should
> find the nid and pid of a process via the name it register with
needs
It's
> the _IO_CONNECT I'm worried about. I'm assuming _IO_CONNECT is sent by
> _connect_ctrl()?
> >> Colin
be
different
> >> seems
> >>> like...)
client),
A),
and
> >> Ok thanks.
server
> >>> Technology
> >> Technology
Yes, I guess so.
I guess the moral of the story is that your system is only as robust as your resource managers!
> -xtang
> and
> now...
> should
> needs
> It's
>> _connect_ctrl()?
>>>> Colin
> be
> different
>>>> seems
>>>>> like...)
> client),
> A),
> and
>>>> Ok thanks.
> server
>>>> Maybe...
