03/26/2009 10:04 AM
post25333
Would it make any kind of sense for /net/localhost to point to the local machine. I know it would make my life easy.
I tried creating a link ( ln -P ) but as I expected that didn't work.
03/26/2009 10:22 AM
post25343
Never had anyone ask for that, but I *think*
you oughta be able to do that, with the process
manager namespace ... even though qnet takes
over the directory /net, you oughta be able to
plop /net/fubar on top of that, which would get
checked first when someone opened it.
Colin?
I seem to recall endless discussions about how
we were going to do the namespace thing, years
ago - I forget how it was finally implemented.
aboyd www.pittspecials.com/movies/torq.wmv
03/27/2009 8:47 PM
post25495
You need to make it a "symbolic" proc symlink ... ln -sP
That will do any path redirection you need.
Thomas
04/06/2009 2:17 PM
post26113
Nope, for:
ln -sP /net/honorificabilitudinitatibus /net/localhost
ln: lstat() failed. /net/localhost: No route to host
> Thomas
That
04/06/2009 2:20 PM
post26114
ln: lstat() failed. Could not spell "honorificabilitudinitatibus"
(OK. That was a useless comment, but there you go).
R.
Sent: Monday, April 06, 2009 2:18 PM
To: technology-networking
Subject: Re: localhost
> > local
work.
Nope, for:
> Thomas
That
Technology
http://community.qnx.com/sf/go/post26113
04/07/2009 9:50 AM
post26206
I'll try again then ...
ln -sP /net/nodename /net/localhost
> R.
> > > local
> work.
> Nope, for:
> > Thomas
> That
> Technology
04/07/2009 10:34 AM
post26220
How about do the way of "mixed dir":
1) before qnet is mounted, "mkdir /net".
2) create the symlink, "ln -sP /net/mybox /net/localhost".
3) start qnet, "mount -Tio-net /lib/dll/lsm-qnet.so; hostname mybox;".
So the /net is a "mixed" directory as both local file system and qnet
are taking in charge of the name /net.
Then you can "cd /net/localhost" to play there.
Weijie
Sent: April 7, 2009 9:51 AM
Subject: Re: RE: localhost
> R.
> > > local
> work.
> Nope, for:
> > Thomas
> That
> Technology
Technology
http://community.qnx.com/sf/go/post26206
04/07/2009 10:54 AM
post26228
In fact, we don't even need to "mkdir /net" if we are using the "-sP" to
the ln command because "-P" makes the link go into the proc manager
prefix tree.
So the step is,
1) before qnet is mounted, create the symlink, "ln -sP /net/mybox
/net/localhost".
2) start qnet.
Weijie
Sent: April 7, 2009 10:34 AM
To: 'post26206@community.qnx.com'
Subject: RE: RE: localhost
Weijie
> R.
> > > local
> work.
> Nope, for:
> > Thomas
> That
> Technology
Technology
04/07/2009 10:58 AM
post26232
> From: Weijie Zhang [mailto:community-noreply@qnx.com]
> Sent: April-07-09 10:54 AM
> to
> prefix tree.
> So the step is,
> /net/localhost".
> 2) start qnet.
Ok but isn't odd that -sP doesn't work afterward?
That being said for us that is no possible because the qnet is first started with a default hostname in the .boot file,
and then when we get access to the file system the hostname is changed. I guess I could change that so that we umount
qnet and then mount it again with the proper hostname.
> Thanks
> Weijie
04/07/2009 11:27 AM
post26242
I guess I agree there might be something not appropriate in qnet of
dealing with symlink.
I am not quite clear on what your target system is. Suppose you have
your own target.build and build your own image, you may do "ln -sP ..."
and define hostname before running io-pkt + qnet. If your system is just
a standard nto box installed on a partition of your hard drive, how
about "echo mybox > /etc/HOSTNAME", so that each time the box is
rebooted, the /etc/rc.d/rc.sysinit will read that file and find the
hostname "mybox" you defined. Because the hostname is not localhost
anymore, the qnet will use what you defined and won't fake one.
Weijie
Sent: April 7, 2009 10:58 AM
> to
> prefix tree.
> So the step is,
> /net/localhost".
> 2) start qnet.
started with a default hostname in the .boot file, and then when we get
change that so that we umount qnet and then mount it again with the
proper hostname.
> Thanks
> Weijie
Technology
http://community.qnx.com/sf/go/post26232
04/07/2009 12:40 PM
post26248
I think the basic issue falls out because ln always tries to lstat()
the destination, to make sure that it doesn't already exist. However,
in the case of qnet, instead of returning ENOENT when it can't find the
destination, it returns EHOSTUNREACH; this confuses ln, so it bails.
The real question for the networking gurus is: is this the right
behaviour? Shouldn't the /net mount point return ENOENT like any other
filesystem? Or should ln (and anyone else who might operate on /net)
treat EHOSTUNREACH the same as ENOENT?
Mario, for your specfic case it might be the most expedient route to
compile your own little application that calls pathmgr_symlink()
directly without doing all the checks that ln does. While it's rarely
a good long-term plan to compile your own system management utilities,
I think it might be a lesser evil than remounting qnet.
Just my $0.02,
-Will
On Tue, 7 Apr 2009 10:58:20 -0400 (EDT)
Mario Charest <community-noreply@qnx.com> wrote:
> > to
> > prefix tree.
> > So the step is,
> > /net/localhost".
> > 2) start qnet.
, and then when we get access to the file system the hostname is changed. I guess I could change that so that we umount
> > Thanks
> > Weijie
> Technology
Will Miles <wmiles@sgl.com>
04/07/2009 1:23 PM
post26252
> From: Will Miles [mailto:community-noreply@qnx.com]
> Sent: April-07-09 12:41 PM
Well I would expect the -P option of ln to totally disregard this. It's suppose to be handled by the process manager,
why care if the basename (/net) exist or not.
We'll just live without /net/localhost. Funny that nobody else felt the need for such a feature, I mean it's in TCP/IP
and even in QNX4 ( node 0 is the local node). Programma
> Just my $0.02,
Input appreciated !
> -Will
> sP"
> > > to
> > > prefix tree.
> > > So the step is,
> > > /net/localhost".
> > > 2) start qnet.
> proper hostname.
> > > Thanks
> > > Weijie
> > Technology
> Technology
> http://community.qnx.com/sf/go/post26248
04/07/2009 2:14 PM
post26264
Comments within quoted text.
On Tue, 7 Apr 2009 13:23:37 -0400 (EDT)
It's the full name it's checking, not the base name. It wants to be
sure that "/net/localhost" isn't a file that already exists before it
creates a symlink with that name; the problem in this case is that
qnet doesn't return 'ENOENT' like it's expecting if the file doesn't
exist. I agree that it would be practical to allow ln -sP to skip these
checks though - and additionally to allow procmgr symlinks to be added
'in front of' or 'behind' a file or directory that already exists,
similar to the way mount points can be overlaid. A clever system
administrator could compose a poor man's failover system with this
facility...
Sounds like it's time to propose a patch to ln!
-Will
04/07/2009 3:21 PM
post26277
Or simply write a one-line code of my_ln_sP.c that calls
pathmgr_symlink().
I've created a PR on ln. Thanks.
Weijie
Sent: April 7, 2009 1:24 PM
Subject: RE: localhost
the
other
suppose to be handled by the process manager, why care if the basename
need for such a feature, I mean it's in TCP/IP and even in QNX4 ( node
> Just my $0.02,
Input appreciated !
> -Will
> sP"
> > > to
manager
> > > prefix tree.
> > > So the step is,
> > > /net/localhost".
> > > 2) start qnet.
get
> proper hostname.
> > > Thanks
> > > Weijie
> > Technology
> Technology
Technology
http://community.qnx.com/sf/go/post26252
