Forum Topic - reference filter for 6.4.0 ?: (13 Items)
Customer is using PPC w. 6.4.0
He wants to create a simple filter to receive a packet from a specific IP addres  and 'reflect' it back as fast as
possible. Initially it is to compare performance with other OSes, but ultimately it is to forward (modified) packets.
His current implementation is a process that receives a packet (from Windows), tweaks it and resends it - via sockets.
It is too slow - he's hoping to do a roundtrip in under 1ms, and he's seeing just over 2ms right now, which I understand
, given it is going up and down the entire stack, copy out, copy in etc.
The question is, is there a good piece of filter reference code (with documentation!) to start from, that he can use to
create his very modest requirement ?
Any pointers greatly appreciated...
Dave
RE: reference filter for 6.4.0 ?
Checkout the "nraw" source
(http://community.qnx.com/integration/viewcvs/viewcvs.cgi/trunk/sys/lsm/
nraw/?root=core_networking&system=exsy1001)
He may not need the resmgr porting, but the nraw_hook.c probably
explained how it is done.
-xtang
> From: Dave Bott [mailto:community-noreply@qnx.com]
> Sent: March 10, 2009 12:00 PM
> To: technology-networking
> Subject: reference filter for 6.4.0 ?
IP
> addres  and 'reflect' it back as fast as possible. Initially it is to
> (modified) packets.
> Windows), tweaks it and resends it - via sockets. It is too slow -
he's
right
> now, which I understand, given it is going up and down the entire
stack,
> documentation!) to start from, that he can use to create his very
modest
> requirement ?
> Dave
> Technology
> http://community.qnx.com/sf/go/post23990
We always hurt in benchmarking small packets, because
of the overhead of the message passing and context
switch between the server (stack) and the client
(eg ttcp).  We can do gige wire rate with ttcp, we
just require a larger payload size to amortize the
overhead.
In the past, we have talked about creating a ttcp.so
dll application which would load into the stack, and
get rid of the context switch and message pass.  Because
there is no message pass through the kernel or context
switch, it would be very fast.  Think "fast-forwarding"
ttcp.
I think that's what you want.
aboyd
Re: reference filter for 6.4.0 ?
> overhead.
> ttcp.
But simple reflection should be possible already via
the hooks provided.  As Xiaodan mentioned nraw is
probably a good starting point.
That sounds like a good idea - how soon can we get it done ?
Dave
> overhead.
> ttcp.
> aboyd
> Technology
> http://community.qnx.com/sf/go/post24013
Dave Bott (dbott@qnx.com)	Field Applications Engineer
QNX Software Systems, Inc.	Cell:408 391-3535
San Jose CA
Join Foundry27 <http://community.qnx.com>;  - the new QNX developer forum.
> Sent: March-10-09 11:28 AM
> Subject: Re: reference filter for 6.4.0 ?
Yes great idea.  I`ll make sure everyone here reads it!
> Dave
> > overhead.
> > ttcp.
> > aboyd
> > Technology
> San Jose CA
> forum.
> Technology
> http://community.qnx.com/sf/go/post24029
There's code here
http://community.qnx.com/sf/wiki/do/viewPage/projects.networking/wiki/Fi
ltering_wiki_page
Showing how to connect into the packet filter infrastructure.  The only
problem is that it doesn't show how to turn the packet around and send
it out again (that's where the nraw code comes in).  This code gives you
full access to the mbuf so you can modify the packet and also indicate
(via the return code) whether or not you want the packet sent up the
stack. There are a few different places that you can hook into the stack
and, I'd suspect for this case, you want to be in the lowest level.
Sean added an input pfil_hook at the ether_input level (the last thing
that the driver calls before passing the packet up the stack).
(see here
http://community.qnx.com/integration/viewcvs/viewcvs.cgi/trunk/sys/net/i
f_ethersubr.c?root=core_networking&rev=659&system=exsy1001&view=markup
for how the hook was added.)
This hook isn't retrievable through the normal "pfil_head_get" function.
Instead, you have to "know" where the hook is (it's a global define).
	pfh_inet = ð_input_pfil_hook;
	pfil_add_hook(input_hook, NULL, PFIL_IN | PFIL_WAITOK,
pfh_inet);
  Note that this hook entry isn't interface specific.  It will be called
by any interface which uses ether_input (and I can't think of any
interface which we currently support which doesn't call ether_input
right now).  You can check which interface the packet came in on in the
filter, though, since the interface pointer is passed as one of the
arguments.
	Robert.
Sent: Tuesday, March 10, 2009 12:00 AM
IP addres  and 'reflect' it back as fast as possible. Initially it is to
(modified) packets.
Windows), tweaks it and resends it - via sockets. It is too slow - he's
right now, which I understand, given it is going up and down the entire
documentation!) to start from, that he can use to create his very modest
requirement ?
Dave
Technology
Re: RE: reference filter for 6.4.0 ?
Thanks for the replies and the information.
I'm not sure I understand enough to use the info you sent Robert.
Neither I, nor my customer, is familiar  enoughwith this code to know what to do with the input hook that you decscribe.
However, looking at nraw, there is a sample app called 'pingd' which I built, and ran, after first installing the nraw
filter. It seems to claim to do ping replies, as well as notice arps and IP packets. It only has an X86 build, so I
don't know if it is endian-safe - I built a PPC and an X86 version of it anyway.
It certainly detects IP and ARP packets, but it did not seem to ping reply correctly - leastways, pinging the box (X86
or PPC) did not get a good reply once this was enabled. It also seems to consume all packets, regardless of the
originating IP address.
Did we write the pingd code, or test it ? Am I using it incorrectly ? It seems like this would be a nicer way to get
what the customer wants - it must be faster via this interface surely, yet still living in a separate process... Or is
this still a bad idea ? Writing a filter looks to be a tricky proposition...
Dave
RE: RE: reference filter for 6.4.0 ?
Using the nraw interface will be faster since it doesn't involve sending
the packet up the stack.  It should also be somewhat faster and less
prone to jitter.
It delivers raw ethernet packets so the customer would have to set up
the appropriate byte pattern (or customize the code) to pick off the
packets that are required.  Hopefully xtang can comment on the pingd
example code (it is, I believe, code that has been written internally).
This will definitely be slower than implementing everything in the
filter since it is crossing the stack process boundary. The filter code
that's provided on the wiki covers the connection into the stack.  If
the nraw code doesn't work out, I'd say just start off using the code
example as is.  The filter point that I talked about in the previous
posting can be easily modifed later. The input / modify portion are
straight forward.  Unfortunately a "simple" example showing how to
create a transmit thread doesn't currently exist.  This is something
that is worthwhile adding to the example, but I can't commit to a time
for doing it right now.  The nraw code does have it in there, but it
obviously needs to be dug out.
	I'll also look at getting that sample code into the source
repository so that it can be checked out rather than having to do a copy
/ paste / create build environment thing.
		Robert.
Sent: Tuesday, March 10, 2009 4:14 PM
Subject: Re: RE: reference filter for 6.4.0 ?
built, and ran, after first installing the nraw filter. It seems to
has an X86 build, so I don't know if it is endian-safe - I built a PPC
reply correctly - leastways, pinging the box (X86 or PPC) did not get a
regardless of the originating IP address.
seems like this would be a nicer way to get what the customer wants - it
process... Or is this still a bad idea ? Writing a filter looks to be a
Dave
Technology
http://community.qnx.com/sf/go/post24077
The "pingd" works for me, I double checked.
The "ip address" you passed to pingd, must be on same subnet, otherwise,
there won't be an ARP send out if it is pinged from some other node.
The "consume all packets", is also intentional. It suppose to show how
to exclusively access the packet. You can change the "open()" in pingd,
*not to* open(O_EXCL), (just O_RDWR), that way, nraw will let the packet
pass through.
If you customer also want performance, he should use a filter module
instead of nraw.
-xtang
> Sent: March 11, 2009 4:14 AM
what
claim
an
> X86 build, so I don't know if it is endian-safe - I built a PPC and an
X86
reply
> correctly - leastways, pinging the box (X86 or PPC) did not get a good
It
it
separate
a
> Dave
> Technology
Thanks Xiaodan,
Yes, I realized that the IP address is the one it will respond to, not the one to expect packets from - that was not
clear to me.
Thanks for the tip on how to pass packets - good stuff to document.
Dave
From: Xiaodan Tang [mailto:community-noreply@qnx.com]
Sent: Wed 11/03/2009 8:29 AM
Subject: RE: RE: reference filter for 6.4.0 ?
pass through.
instead of nraw.
-xtang
what
claim
an
X86
reply
It
it
separate
a
> Dave
> Technology
Technology
http://community.qnx.com/sf/go/post24143
Attachment: Text winmail.dat 5.4 KB
I've nearly got things working right - currently using nraw (it would
help a lot if it were *documented*...)
I can bounce a UDP packet ck bain my process, but only if I set the
return checksum to 0 (i.e. disable checksums) - I don't seem to be able
to calculate it correctly.
I'm trying to use the cksum() code in the pingd example code, but that's
for icmp/arp stuff - so is that the wrong sort of checksum ?
I'm also a bit unsure of exactly *what* to checksum - I think it's
everything after the ethernet header - so is that everything after the
first 14 bytes, setting the checksum field to 0, or is it more
complicated than that ? I tried checksumming the incoming UDP packets
(from some packet generator code the customer gave me) but I can't get
it to match...
nraw is cool, but writing some notes on how to use patterns (I'd like to
specify 2 to use together to restrict to a given port and IP, but don't
know how), and some examples of how to create each packet type would
make it really *useful*... Otherwise, we're back to the old adage : "a
week in the lab can often save an hour in the library" :-)
Any help available ?
Thanks !
Dave
> pass through.
> instead of nraw.
> -xtang
> what
> claim
> an
> X86
> reply
> It
> it
> separate
> a
> > Dave
> > Technology
> Technology
San Jose CA
Hi Dave:
UDP packets include checksums for both the IP header and the UDP packet
http://www.networksorcery.com/enp/protocol/ip.htm
http://www.networksorcery.com/enp/protocol/udp.htm
Nraw is brand new so hasn't been documented yet.  We should add a quick
blurb on it in the Networking wiki.  As a side note (and for emphasis),
there is no intent to ship it with product in binary format.  It is
intended to be used as a source code example for people interested in
how to connect into the stack and provide a resource manager interface.
		R.
Sent: Thursday, March 19, 2009 12:32 AM
it to match...
Thanks !
Dave
> otherwise, there won't be an ARP send out if it is pinged from some
other node.
> pingd, *not to* open(O_EXCL), (just O_RDWR), that way, nraw will let
> the packet pass through.
> instead of nraw.
> -xtang
> > know
> what
> > I built, and ran, after first installing the nraw filter. It seems
> > to
> claim
> > has
> an
> > an
> X86
> reply
> > packets, regardless of the originating IP address.
> It
> > seems like...
