Forum Topic - select() call is not working: (3 Items)
HI,
 any one can help on this.
select() call is not working on file descriptors. it is not all blocking.
#include<sys/select.h>
#include <sys/syspage.h>
#include <fcntl.h>
#include"nipcinternonblk.h"
	int sel_res, fd;
	fd_set rd_set;
	fd = open("/tmp/tst",O_RDWR );
while(1)
	printf("entered whl loop\n");
	FD_ZERO(&rd_set);
                FD_SET(fd,&rd_set);
	sel_res = select(FD_SETSIZE, &rd_set,NULL,NULL,NULL);
	printf("select val:%d\n",sel_res);-----------> always giving 1
	if(FD_ISSET(chid, &rd_set ))
                          do something..............
RE: select() call is not working
> From: rajesh k [mailto:community-noreply@qnx.com]
> Sent: February-20-09 5:41 PM
> To: technology-networking
> Subject: select() call is not working
> HI,
> blocking.
> #include <fcntl.h>
> 	int sel_res, fd;
> 	fd_set rd_set;
> while(1)
> 	FD_ZERO(&rd_set);
>                 FD_SET(fd,&rd_set);
I believe FD_SETSIZE should be equal to fd + 1.  That being said under QNX6 it don't think it makes any sense to do a
select on a file description that is pointing to a file.
> Technology
> http://community.qnx.com/sf/go/post22673
Re: select() call is not working
On Fri, Feb 20, 2009 at 05:40:39PM -0500, rajesh k wrote:
> HI,
> #include <fcntl.h>
> 	int sel_res, fd;
> 	fd_set rd_set;
> while(1)
> 	FD_ZERO(&rd_set);
>                 FD_SET(fd,&rd_set);
Returning from select() for read means you won't block on read which
I suspect you won't in this example.
